Keeping items in the 12v socket - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 8Likes
post #1 of 25 Old 09-26-2018, 03:44 AM Thread Starter
Any tips on keeping a plug in the 12v socket while riding? If I try to plug in a phone charger while riding it vibrates loose. I've thought about switching it for a USB outlet, but then tire inflator wouldn't work....
DesertBike likes this.
dakor82 is offline
post #2 of 25 Old 09-26-2018, 04:34 AM
Switch to a USB outlet on the handlebars, and put a 12V cig lighter socket directly on the battery, under the seat. You're not going to use the tire inflator when riding anyway, and I bet that everything you need while riding is USB-powered.
This will work just nicely, but it's by no means the only source.
https://www.aliexpress.com/item/12V-...ceBeautifyAB=0
pvwheeler and Kerri Miller like this.
BackPacker is online now
post #3 of 25 Old 09-26-2018, 05:31 AM
pvwheeler's Avatar
Yes replace it with a usb outlet. A tire pump will blow the fuse instantly anyways.
Kerri Miller likes this.
2015 Wee2 EXP "Arya"
2002 DR650 SM "Tormund"
2014 CB500x (wifes)
2018 XT 250 (wifes)
pvwheeler is offline
post #4 of 25 Old 09-26-2018, 08:40 AM
I am studying the Anderson Powerpole type connector for heated gear, tire pump and battery tending. Has anyone fitted these connections anywhere?
I currently have SAE connectors for those items but not loving them. Everything else converted to USB. I would not stand the accessory plug for the GPS popping out so hardwired some USB ports with voltage display. Cigarette type outlet only for unplanned usage.
kfh000 is offline
post #5 of 25 Old 09-26-2018, 09:17 AM
I use electrical tape around the top of the socket to create a tight seal. My concern is rain as well. USB use in the rain is an issue for me, so I avoid it.
Sullaha likes this.
Hatchi is offline
post #6 of 25 Old 09-26-2018, 09:23 AM
It is a good place to keep a stack of dimes. You will need a spare fuse though if you want to then use the socket for power. kfh000
kfh000 is offline
post #7 of 25 Old 09-26-2018, 10:16 AM
Buy a better outlet. The first I had was always having the GPS plug vibrate out. I switched to a marine grade unit and no more problems. If you fuse the outlet with a 15 amp fuse you can run a tire pump.
Have a second USB outlet is practical since so many toys work that way now. There are some dandy outlets that have the voltage meter built in too.
post #8 of 25 Old 09-26-2018, 12:29 PM
alfie53's Avatar
I've solved that lttile issue by wrapping just one or two layers of electrical tape around the bottom half of the adaptor. It is plasticky and compresses when twisted and pushed in to form a tight joint.
I have also gone the route of waterproof USB attached to the engine bars. It's a 15A job that can power phone, sat nav and any other smaller items but also a tyre pump without blowing the fuse
when needed
alfie53 is offline
post #9 of 25 Old 09-26-2018, 04:50 PM
Bad Dad's Avatar
I just wedge a end of a zip tie in there. Also run a separate cig. Type outlet, this, https://goo.gl/images/HHbDBt
2002 DL 1000
Bad Dad is offline
post #10 of 25 Old 09-26-2018, 04:51 PM
Bad Dad's Avatar
The spring in the cap keeps sockets secure and closed it's pretty weatherproof, 50,000 plus trouble free miles!
2002 DL 1000
Bad Dad is offline
12V socket keeps killing USB car chargers DesertBike Techy World! GPS, Electronics, etc 4 11-09-2016 08:12 PM
Tool tip for road trip Maxkull V-Strom Service and Maintenance Questions and Discussions 8 08-20-2016 04:14 PM
Repair Tools - What I Carry BanditDave V-Strom Service and Maintenance Questions and Discussions 10 01-08-2016 01:27 AM
noise filter for power socket? Gravehunter General V-Strom Discussion 18 02-15-2009 07:29 PM
Powerlet Socket Issue- Looking for Feedback E-Nigma Techy World! GPS, Electronics, etc 6 12-30-2008 08:05 AM
