Booster plug on 2014 dl1000 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 7Likes
post #1 of 33 Old 09-09-2018, 11:07 PM Thread Starter
So what exactly does a boosterplug do.. I looked at the website and what they claim. I've had the ECU replaced on my 2014 and have had no complaints. I am the second owner of the bike. I bought it with 11k on the clock and the first owner never replaced the ECU. He did put an akropovic exhaust on it. I have no complaints, but am not opposed to improving performance if it in no way compromises longevity. If there a reason I should get one. Would it make sense to sell the exhaust for a profit and go back to a stock one? Or should I do nothing? It's a bit rough below 2500 rpm but I twist a little harder in any gear and it fixes itself. Bike has never stalled in any gear except first when I newto it and had a hangover, total user error.... I have put 7k on it this year.
dakor82 is offline
post #2 of 33 Old 09-17-2018, 06:48 PM
It's my understanding that the booster plug changes the coolant temp signal to the ECU essentially telling the computer the engine isn't fully warmed up and lets it have a richer mixture.
NortheastJoe is offline
post #3 of 33 Old 09-17-2018, 07:47 PM
blaustrom's Avatar
Google is your friend, do a search of this site:
https://www.stromtrooper.com/dl1000a...dl-1000-a.html
NVDucati likes this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #4 of 33 Old 09-18-2018, 10:07 AM
Feral Donkey's Avatar
It fools the mass air flow sensor into thinking it's 20 degrees cooler than it really is so the brain box richens things up a bit. I have one on my K6. It's a resistor. One guy I know put a 5k ohm variable resistor in line instead and that's his hillbilly tuner.
Feral Donkey is offline
post #5 of 33 Old 09-20-2018, 08:09 AM
alfie53's Avatar
As mentioned, it fools the bike's brain into enrichening the mixture. I had one on my BMW F800 to tame a snatchy throttle response due to lean running.
With the new ECU on my nicely running V2 I'm not convinced it'll make any difference at all.
My advice would be to save your money if your bike runs well.
alfie53 is offline
post #6 of 33 Old 09-20-2018, 10:52 AM
Spec's Avatar
The BoosterPlug is not just a resistor according to them:
"The BoosterPlug is the only Plug and Play device that offers a stabilized enrichment of the mixture in different ambient temperatures.
- To do this, the BoosterPlug is using an extra temperature sensor (and a few other components), that will work in cooperation with the original Air Intake Temperature Sensor."
Spec is offline
post #7 of 33 Old 09-20-2018, 12:19 PM
NVDucati's Avatar
The link blaustrom cites really covers it. I have one and highly recommend it. My comments (2) can be found at the link above.
Member: AMA
NVDucati is offline
post #8 of 33 Old 09-27-2018, 10:59 PM
Just got a 2014 DL1000, has 20,000klm on it (12,00 miles).. How would I know if the ECU was replaced? Was this a recall or technical bulletin?
karjar is offline
post #9 of 33 Old 09-27-2018, 11:56 PM Thread Starter
I went to a dealer and asked them to check it...
dakor82 is offline
post #10 of 33 Old 09-28-2018, 12:55 AM
Karjar,it was termed 2012-2015 DL1000A/AA ECM Service Campaigns 2A74 and 2A75. TL/SV/DL No.66, 10/20/17
take off the bike's seat. Look at the numbers on the ECU label( ECU located between the battery and the seat latch).
If the last 3 letter/numbers are: J10, J11, J20, J21 the ECU needs to be replaced.
If the last 3 letter/numbers are: J12 or J22 the ECU does not need to be replaced.
Affected Models Model Year VIN Range
DL1000A/AAL4 2014 JS1VU51A_E2100025--JS1VU51A_E2102822
DL1000A/AAL5 2015 JS1VU51A_F2100011--JS1VU51A_F2100500
This from the Dealer Service letter I had them print out.
karjar likes this.
MAZ4ME is offline
how much better is the 2014 DL1000 Hedgehorn DL1000 from 2002-2012 14 08-24-2015 12:07 PM
Can you upgrade Wee suspension to ride similar to new 2014 DL1000? augie05 DL650 and DL650A - 2004 to 2011 5 08-16-2014 08:48 PM
2014 DL1000 Isle of Man video oldsport DL1000A - 2014-2016 1 08-05-2014 02:36 AM
