Signal lights and hazards not working! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 08-03-2018, 02:03 PM Thread Starter
Hi Folks, first post here...I have a weird issue, when bike is on or switch is on, ALL hazards and signals not working. when switch is in park mode, every thing is normal and working. I thought it might be flasher relay, ordered one and tries, same issue. Please help!
Thanks,
Alex
Aceofmen1 is offline
post #2 of 5 Old 08-03-2018, 07:57 PM
stu53's Avatar
Have you tried replacing the signal fuse under the seat? Possibly a different circuit may be used for the signals when on "Park" compared to when ignition is on, which could explain why they aren't working when the ignition is on.
DL1000A 2014
previously DL650K6
stu53 is offline
post #3 of 5 Old 08-19-2018, 04:28 AM
Ryohn579's Avatar
Started by DL1000A up the other day and first corner discovered no indicators. Had them a week prior and assuming its the flasher relay as no hazards or indicators. Have checked fuse and its all good.
Any suggestions?
Ryohn579 is offline
post #4 of 5 Old 08-19-2018, 05:30 AM
stu53's Avatar
After reading up after the OP past I would check if the hazards work when the key is turned on to park. If they do work it may be an issue with power from the ignition switch.
DL1000A 2014
previously DL650K6
stu53 is offline
post #5 of 5 Old 08-19-2018, 10:00 AM
Brockie's Avatar
The only issue I have had with indicators/hazard flashers have been in the LH switchblock after getting water in there. Fixed by Electroclean and working the switch.
Brockie is offline
