2014 DL1000 Front Caliper Pin Machined Step? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 06-26-2018, 04:12 PM Thread Starter
Hi Fellows
I just changed my front brake pads and my pad pins seem to have a slight machined step of slightly less diameter in the center of the pin about half an inch long on all of them.
It does not look like wear, but I am a little concerned.
Has anyone noticed this?
Toto is offline
post #2 of 4 Old 06-27-2018, 06:09 AM
stu53's Avatar
Yes and I am sure it's normal.
DL1000A 2014
previously DL650K6
stu53 is offline
post #3 of 4 Old 06-27-2018, 08:54 AM Thread Starter
Thanx, Stu
I did some more research online and it does appear to be normal.
Thanx, again.
Toto is offline
post #4 of 4 Old 06-27-2018, 12:32 PM
It is normal, When I replace the pads I clean the pin sometimes with a wire wheel on the grinder then put a very light coat of grease on it.
Buffalo rider is offline
