backfire on decleration with yoshi exhaust - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
post #1 of 11 Old 05-27-2018, 09:27 PM Thread Starter
newfienighthawk's Avatar
anyone have a fix for backfire on declaration when they run after market exhaust?im running Yoshi
newfienighthawk is offline
post #2 of 11 Old 05-27-2018, 11:10 PM
Brockie's Avatar
Backfires on deacceleration are often caused by leaks in the exhaust system - allowing oxygen-rich air to get in with the hot exhaust gases.
Try reinstalling your exhaust system using exhaust leak sealant.
Brockie is offline
post #3 of 11 Old 05-27-2018, 11:13 PM
BrianS's Avatar
Do you have a full system or a slip-on? Although I have a stock pipe right now, three aftermarket slip-ons and full exhausts I had in the past had this problem. I went with a fuel controller on Yamaha FZ1, FZ07 and Honda CB500F ...
Toronto, Canada
2015 V-Strom 1000
BrianS is offline
post #4 of 11 Old 05-27-2018, 11:41 PM Thread Starter
theres no leaks for sure,i double check and had my dealer check it out that was no leaks
post #5 of 11 Old 05-27-2018, 11:43 PM Thread Starter
Its a slip on exhaust Yoshi r77 stainless
post #6 of 11 Old 05-28-2018, 12:03 AM
Brisky's Avatar
Did you take the DB Killer out? My Arrow popped when I had it out but never with it in
Brisky is offline
post #7 of 11 Old 05-28-2018, 12:49 PM
Exhaust backfires/pops on decel can also occur when the idle mixture is too lean, which is a pretty common problem with today's bikes in order for them to meet EPA regs. Adding a PCFC with the proper idle mixture or getting a reflash would likely solve the problem. The addition of an aftermarket pipe tends to lean out the mixture a little, so it could cause the problem when no problem existed before the system was added.
dravnx and BrianS like this.
bobbyvstrom is offline
post #8 of 11 Old 05-28-2018, 01:25 PM
vanislejay's Avatar
Do these bikes have a PAIR system like the older ones? If they do it's a likely culprit.
vanislejay is offline
post #9 of 11 Old 05-28-2018, 06:21 PM
Mine backfired with a Leo Vince slip-on, factory recall on the ECM fixed it.
terryfulks is offline
post #10 of 11 Old 05-28-2018, 06:24 PM
ToadRide's Avatar
Full arrow and Yosh on mine. ECM replaced and decel pop (not backfire) down from many to one or two.
2014 V2. Givin it a likkin and it's still tickin!
ToadRide is offline
