Scoring noise from engine - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
post #1 of 11 Old 05-15-2018, 02:37 PM Thread Starter
Nelly3154's Avatar
Hi folks looking some advice am new to the vstrom world and loving it so far so here goes was away for weekend on the bike 2014 dl1000 al4 done just over 1000 miles over weekend on way home clutch fluid was low so topped up but started to get a scoring noise coming from the engine in all gears and at all speeds seemed to get louder the more the engine laboured but noise disappeared when clutch engaged this seemed to happen when engine was warm as got of ferry after 3 hours engine cold no noise can anyone advise?
Nelly3154 is offline
post #2 of 11 Old 05-15-2018, 02:41 PM
I would be worried about why the clutch fluid was low, and sounds like you are possibly hearing "clutch chudder" but it's well documented and harmless.
post #3 of 11 Old 05-15-2018, 02:46 PM Thread Starter
Nelly3154's Avatar
Thanks for the reply big b i am stripping down the slave cylinder tomorrow to rebuild with new seals hoping this is the problem with the oil level will look through the threads about the chudder is that an easy fix ?
post #4 of 11 Old 05-15-2018, 02:51 PM
I highly doubt you are in need of a rebuild "rare for clutch slave seal failures", likely you have too much lube build up around the slave area, the push rod shaft will cause the push rod seal to leak oil, but if you are actually losing clutch fluid you should easily be able to tell. But crud getting into the slave cylinder is possible, but once again that is a bit rare. And yes there is a fix for the "idle hammer", I meant that and not clutch chudder. Terry Hinkle "Realshelby" is a member here and quite the machinist and brilliant problem solver.
https://www.werksparts.com/idle-hammer-tamer.html
post #5 of 11 Old 05-15-2018, 03:51 PM Thread Starter
Nelly3154's Avatar
Thanks big b forgot to mention this is the third time topping up the fluid so defo losing it somewhere just this is the first time experiencing the scoring noise will look further into this thanks again for the help much appreciated 👍
post #6 of 11 Old 05-15-2018, 05:34 PM
larolco's Avatar
Not so in my case. On my fourth or fifth now. It's not a good design for an "ADV" bike. All it takes is for one little piece of grit to get near the seal and its days are numbered. When you ride in the wet and grime, invariably, it finds its way in.
Almost certainly, if he's losing clutch fluid, the slave seal is the culprit.
DRZ400SK17
larolco is offline
post #7 of 11 Old 05-15-2018, 07:52 PM
I did have a leak on my 06 1000 and replaced the seal, yet another reason why I don't miss owning a 1000. My 650 XT has been through far far far worse than either of my previous 1000's, it just takes the punishment and keeps begging for more. Yeah the Vee's has a bad design for sure, most hydraulic slaves are more/better suited to shaft drives than chain drive bikes, but there are plenty of chain drive ADV machines with hydraulic slaves which have next to zero issues.
Have yet to hear the term "scoring noise" here so I am still a bit confused by that. LOL
post #8 of 11 Old 05-15-2018, 08:19 PM
Rolex's Avatar
If you do a search on here you will find some of us have made covers for the push rod to keep the crud off and save the seal.
Now while you have it apart would be a good time to make one and fit it.
I used a very light spring with some heat shrink over the spring, be warned the motor seal can be easily pushed back into the motor so something light is required as a cover.
Big B likes this.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #9 of 11 Old 05-16-2018, 01:30 AM Thread Starter
Nelly3154's Avatar
Thanks rolex will look into this when stripped as for the term i have used as scoring its like grinding rubbing noise which went away when clutch was engaged it completly disappeared when engine was cold i havnt had bike out again to see if this happens again when engine is hot
post #10 of 11 Old 05-16-2018, 10:27 AM
Yup appears to be the "idle hammer"......annoying but harmless, and it's only a 1000 Vee phenomena.
