OK, A little help... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
post #1 of 15 Old 05-23-2017, 11:42 PM Thread Starter
OregonMike's Avatar
Can someone, PLEASE, snap a picture of the owners manual on the pages to set the freaking clock.... It's about 3 hours fast... or 9 hours behind.... cant figure that out.....
OregonMike is offline
post #2 of 15 Old 05-24-2017, 12:16 AM
Bugzy's Avatar
Its pretty easy once you know how.
Push the Sel and ADJ buttons at the same time, hold for 3 or 5 seconds or something, you will see the clock start to flash. Change the hours with up/down on mode button, then hit ADJ to move to minutes and repeat, when done you hit Sel and Adj together again.
I think that is all you need to do, let me know you get stuck and I will go have a look.
Bugzy is offline
post #3 of 15 Old 05-24-2017, 12:24 AM
wingstrom is offline
post #4 of 15 Old 05-24-2017, 12:29 AM
A simultaneous button push is not so easy. Push the right button a little early and it won't work. Push the left button a little early and it works fine.
post #5 of 15 Old 05-24-2017, 12:34 AM Thread Starter
OregonMike's Avatar
Hmmm... at that managed to do was reset the trip meter
position of the key matter??
650 different from the 1000???
post #6 of 15 Old 05-24-2017, 12:54 AM
It sounds like you weren't holding down the select button or didn't press it first before you pushed the adjust button.
post #7 of 15 Old 05-24-2017, 01:11 AM Thread Starter
OregonMike's Avatar
tried it 20 times 5 different ways..l am stupider than a clock...
IDRIDR likes this.
post #8 of 15 Old 05-24-2017, 01:12 AM
The picture I posted above is from the manual for a '16 dl650. I thought your post was on the 650 forum. I should probably wear my glasses when looking at my phone.
post #9 of 15 Old 05-24-2017, 01:32 AM
Bugzy's Avatar
Sorry, my description was a little off.
Hopefully you can read this. It is for 2014 DL1000a
Bugzy is offline
post #10 of 15 Old 05-24-2017, 02:01 AM Thread Starter
OregonMike's Avatar
Well that worked.... I am now time compliant. Thanks all...
