Traction control - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 05-01-2017, 11:52 PM Thread Starter
Traction control
Im looking at a 2014 strom 1000 and im wondering if the traction control can be shut off so i can weely the bike with no interfearance. I know its not legal and i wont be weelying through the local school yard. Just wondering if its possable on the bike
Wayne Shrum is offline
post #2 of 13 Old 05-01-2017, 11:58 PM
symbiotix's Avatar
Yes it can be shut off. ABS cannot be however.
symbiotix is offline
post #3 of 13 Old 05-02-2017, 12:01 AM Thread Starter
Ahhh good to hear thank you
post #4 of 13 Old 05-02-2017, 12:27 AM
ABS can be defeated by pulling a fuse, installing a switch or getting the wheels to move at different speeds for a while by spinning the rear in loose dirt, on a center stand or, interestingly enough, wheelieing.
post #5 of 13 Old 05-03-2017, 12:38 AM
What you will also like is that the TC stays off the next time you start the bike...
2015 DL1000 ADV
2thDr is offline
post #6 of 13 Old 05-03-2017, 03:19 AM
BorisB's Avatar
I don't recommend doing it until after the warrantee is up, but adding a switch to turn off the ABS is pretty easy. You can switch it off on the fly and when you turn it back on it comes back in about 5 seconds.
BorisB is offline
post #7 of 13 Old 05-03-2017, 08:51 AM
Motor7's Avatar
Not on the 650's. Both gen 1 and gen 2 require the bike to be turned off and re-started after flipping the ABS cut off switch back to "on". Are the DL1000's or gen 3's different?
15 DL650XT
Motor7 is offline
post #8 of 13 Old 05-03-2017, 09:34 AM
You're switching the wrong wire. Another wire in the ABS system allows on the fly switching. Proper ABS on/off switch
See post #39 for Gen 2.
post #9 of 13 Old 05-03-2017, 09:48 AM
Motor7's Avatar
Interesting, I used the EB kit and didn't realize there were two matching plugs. I'll take another look next time the tupperware is off...valve check is already overdue at 17K and change.
15 DL650XT
Motor7 is offline
post #10 of 13 Old 05-03-2017, 10:12 AM
The EB kit won't work to restore ABS on the fly. A different wire has to be cut and each side of the cut ends extended to a switch. It isn't plug and play.
