Question about upgrading from a 2012 dl1000 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 04-22-2017, 03:59 PM Thread Starter
Going to trade in the 2012 to a 2016 and was wondering big difference between the two
nickvolvo40 is offline
post #2 of 4 Old 04-22-2017, 08:58 PM
Stromaholic's Avatar
Handling.....
Never argue with an idiot.......they drag you down to their level, then beat you with experience!
Stromaholic is offline
post #3 of 4 Old 04-22-2017, 09:15 PM
Bugzy's Avatar
Brakes, instruments, suspension, noticeably lighter.
It has gear indicator, thermometer, voltage meter, ABS. I don't find the TC useful but it is there to play with. Gearing is set right from the start. Stock seat is better.
It is an improvement all around.
Bugzy is offline
post #4 of 4 Old 04-22-2017, 10:54 PM
alon's Avatar
i would look at the AT or the 1090 adv r if you are going to do off road (this bike was not designed for it
unless you are planning to buy a new 14' or something alike (then there is a major price difference)
2014 vee2- OEM:skid plate,heated grips,mirror extenders,centerstand. aftermarket:sw-motech: risers,trax 45L side cases 38L top case,pipe valve guard, kickstand foot enlarger. corbin/holshot heated seat ,MRA VarioTouringScreen,burkbusters storm,PC8, kaoko throttle lock, scorpion titanium slip-on, denali airbomb,scottoiler,denalli dx.pc5+autotune R&G:radiator guard, pipe slider K&N:air filter touratech:crashbars, ABS kill switch,dryspec tool tube,cyclops LED headlights,doubleback mirrors,helmet guardian,twowheels shorty levers,aftermarket off road rear brake lever,shorai lithium battery.
alon is offline
