Top of dash loose - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By bosnjo
post #1 of 8 Old 04-19-2017, 10:44 PM Thread Starter
Bugzy's Avatar
Top of dash loose
I had my dash apart to install the H7 low beam light recently and now I see the top of the instrument cluster, the RPM and speed indicator display, is loose at the top. How is that attached, does it snap into something?
I am not referring to the frame part, that is attached and solid, this is the actual instrument part that fits inside the frame.
Bugzy is offline
post #2 of 8 Old 04-19-2017, 11:37 PM Thread Starter
Bugzy's Avatar
Well I took it apart and at the top of it is a purpose built hole for a bolt and screw, but the hole for it was covered up by a rubber sticker, like it was deliberately in there without a bolt to hold it in place.
Maybe the dash is supposed to float around in the housing? It just seems odd because I can push at the top of it and it moves 1/8th of an inch, and there is a gap around it where dirt and water can get inside, that doesn't seem right.
I fashioned a bolt to fit in the top and now it is rock solid. I suppose it will fall apart now on bumps or something.
Bugzy is offline
post #3 of 8 Old 04-20-2017, 12:04 AM
My gauges will move as well so that has to be normal. It seems odd but must serve a purpose. Vibration isolation?
moglink is offline
post #4 of 8 Old 04-20-2017, 12:48 AM
blaustrom's Avatar
Mine is exactly the same. I have it all stripped apart to add some wiring and was concerned that when pulling the whole instrument assembly out of the rubber grommet in the rear there is a lot of play and its held together only by the 2 lower bolts. I added a small zip tie at the top where you used a screw. But I left the tie loose with some play. It now helps pulling the instrument cluster out of the rubber grommet but its still rather loose.
blaustrom is online now
post #5 of 8 Old 04-20-2017, 06:23 AM
bosnjo's Avatar
I had the same problem and my dealer suggested the easy fix.
Put one or two rubber washers on the pin behind the clocks and then insert it back in on assembly. I tried that and used two rubber washers I got at hardware store. I bought those for bathroom shower hose and they worked perfectly. My clocks are now rock solid.
Bugzy likes this.
2017 DL1000 White
2014 DL1000 Red (sold)
2012 DL650 White (sold)
bosnjo is offline
post #6 of 8 Old 04-20-2017, 07:13 AM
V2man's Avatar
Question
Problem?????
How is this a problem, were you experiencing dash readout issues?
Has any one reported dash failure from this movement?
I think the first report of dash failure will be one of the above....IMHO
It is designed to move, whether Suzuki saw it as a shock absorber of some kind for rough/off road or a form of vibration dampner.
I reckon if you run a poll you will find every V2 has this movement.
Just my 2cents worth.
Cheers V2man
2014 DL1000A 2014 -
2012 DL650L2 2013 - 2014
2007 DL1000 "Bowser" 2009 - 2013
V2man is offline
post #7 of 8 Old 04-20-2017, 08:53 AM
bosnjo's Avatar
My dash has never failed but it was shaking badly. On 2nd year of owning the bike, it started to buzz on certain revs. After I've fixed it's been solid and silent.
The problem has to do with rubber grommet widening with age.
2017 DL1000 White
bosnjo is offline
post #8 of 8 Old 04-20-2017, 10:44 PM
Mattbastard's Avatar
Mine was like that too, til I secured it with a zip tie.
Trying to find the perfect bike, one bike at a time. The doctors say there's no cure.
Mattbastard is offline
