Headlights Relay Install, anyone done it? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 04-15-2017, 12:22 PM Thread Starter
blaustrom's Avatar
I am wrestling if or if not to attempt a headlights relay install. The high beam is no big problem, other than finding space, you can get H9 male/ female extensions that will work to connect to the relay. However the sealed low beam H7 can only be properly connected on the outside of the housing. There is a sealed 2 pin connector, see below. Anybody fingered out where to get such a set of connectors?
blaustrom is online now
post #2 of 5 Old 04-15-2017, 12:35 PM
If Eastern Beaver has a relay/harness kit available I highly recommend it. Better quality than OEM and plug and play.
realshelby is offline
post #3 of 5 Old 04-15-2017, 03:54 PM
Anthony_L's Avatar
I'll second that.. maybe a PC8 too!
Anthony_L is offline
post #4 of 5 Old 04-15-2017, 04:16 PM Thread Starter
blaustrom's Avatar
I know, I have various harnesses for my WEE and the rear harness for the V2. He has no front headlight harness for the V2. I just asked him about it but no answer as of now. That's why I am looking for help to see if somebody has figured it out.
Seems there have been no reports of connector or switch failures related to the headlights for the V2 but I try to play it safe and not having to worry about it in future.
post #5 of 5 Old 04-16-2017, 12:53 AM
Bugzy's Avatar
Maybe with the single headlight up front you don't need to worry about it? Just switch to LED and call it done.
Bugzy is offline
