Gel Gloves - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 7Likes
post #1 of 17 Old 04-14-2017, 04:14 PM Thread Starter
pats's Avatar
Gel Gloves
Anyone in the forum using gel gloves to eliminate the hand vibration?
pats is offline
post #2 of 17 Old 04-14-2017, 05:32 PM
What is this hand vibration you speak of? Get some better grips, don't squeeze so hard, and or consider some Grip puppies if you haven't yet. I have never experienced any hand vibes on 3 different V-Stroms, you either have something causing it or have sensitive hands.
V-Tom, notacop, 2wheelrob and 1 others like this.
post #3 of 17 Old 04-14-2017, 06:51 PM
Bugzy's Avatar
Grip puppies work. I haven't needed them on my V2 though, they cause a delay in the heated grips.
If you get grip covers, be sure to get the neoprene ones, not the cheap foamies, the foamies tear on your first ride, or did for me.
Bugzy is offline
post #4 of 17 Old 04-14-2017, 07:49 PM
shu
shu's Avatar
Yes, I do.
IMO all bikes vibrate, at different 'wavelengths', some worse than others but they all pass some vibration to the rider.
I've worn Olympia gel palm gloves for 15 years now, on many different bikes. They are fairly lightweight leather, but well made and I've crash tested them a few times successfully.
I like these: Olympia 400
and these: Olympia 452
They make a difference for me.
...........shu
shu is offline
post #5 of 17 Old 04-14-2017, 08:15 PM
Macdoc's Avatar
Grip Buddies or Grip Puppies....work the charm. Even my 650 single is tamed. The gel really does not cover enough area
Canada 2018 CB500x >2009 CBF1000 sold 10 Wee ABS sold09 Burgman Exec sold • 10 NT700v sold
Australia> 04 KLR65093 ST1100 sold
Macdoc is offline
post #6 of 17 Old 04-14-2017, 09:17 PM Thread Starter
pats's Avatar
I have the Oxford heated grips and thought of gloves instead of the grip puppies so I could take advantage of the heat when needed. Can I find the grip puppies at a bike shop or better off online? I just did 1,800 mi. in 6 days and in the mornings I always used the heat for awhile.
pats is offline
post #7 of 17 Old 04-14-2017, 09:20 PM
Bugzy's Avatar
You can buy them both online and in stores usually, but I find there are a lot of the foam ones out there that look exactly the same, but fall apart, so just be careful you get the real thing if you buy in a store.
Bugzy is offline
post #8 of 17 Old 04-14-2017, 10:51 PM
jrdunn96's Avatar
I dunno, my K4 seems "smooth as butter" to me. JMHO
jrdunn96 is offline
post #9 of 17 Old 04-14-2017, 11:20 PM
Just be aware that Grip Puppies will make the grip feel quite a bit larger. I ultimately took mine off because I didn't care for that. There are also replacement grips that get good reviews for vibe reduction and are more nearly stock size.
D'oh! ...forgot you had Oxfords, so replacing grip not an option for you.
-Gary
2016 GSX-S1000FA
2012 DR650SE
2011 Burgman 400
2007 Honda Helix
2013 V-Strom 650 - sold
G-Dub is offline
post #10 of 17 Old 04-15-2017, 10:05 AM
GotaV2's Avatar
The grip puppies are good but as said make the grip larger may take a bit of getting used to.
You can also get grip pussies they are not as thick as the puppies.
We have tried both and prefer the puppies for both the strom's and Dr's so maybe try both and see how you feel about them as they are not to expensive.
Cheers GotaV2
2014 DL1000AL4-Glass Glacier White
OEM centre stand,chain guard,decals,SW-Motech,crashbars,pannier racks,brake,exhaust,master cylinder guards, footbase,ROX risers,Givi Hugger, Airflow, panniers,top box,PivotPgs,OmniC,Rad Guard,mirror extenders,3 Guardian Bells, Oxford HG,Tutoro, Zumo 590, PC8,Crees, G2,Grip puppies,helmet hook,SitnFly,2xBC tank bag & ring,Ventura HP,FP lowering kit,SPOT,Backoff,2 Tool Tubes,Sena 10s,Contour,Hwy pegs, 2 Aux plugs,MJM seat,levers,Barrett Exhaust,Stebal Horn,Personalised Rim tape,PP & Holder, Barkbusters & Led,smiley face
2012 DL650AL2-Pearl Mirage White "Sparkles" 2011-2014
GotaV2 is offline
