What is this hand vibration you speak of? Get some better grips, don't squeeze so hard, and or consider some Grip puppies if you haven't yet. I have never experienced any hand vibes on 3 different V-Stroms, you either have something causing it or have sensitive hands.
IMO all bikes vibrate, at different 'wavelengths', some worse than others but they all pass some vibration to the rider.
I've worn Olympia gel palm gloves for 15 years now, on many different bikes. They are fairly lightweight leather, but well made and I've crash tested them a few times successfully.
I have the Oxford heated grips and thought of gloves instead of the grip puppies so I could take advantage of the heat when needed. Can I find the grip puppies at a bike shop or better off online? I just did 1,800 mi. in 6 days and in the mornings I always used the heat for awhile.
You can buy them both online and in stores usually, but I find there are a lot of the foam ones out there that look exactly the same, but fall apart, so just be careful you get the real thing if you buy in a store.
Just be aware that Grip Puppies will make the grip feel quite a bit larger. I ultimately took mine off because I didn't care for that. There are also replacement grips that get good reviews for vibe reduction and are more nearly stock size.
D'oh! ...forgot you had Oxfords, so replacing grip not an option for you.
The grip puppies are good but as said make the grip larger may take a bit of getting used to.
You can also get grip pussies they are not as thick as the puppies.
We have tried both and prefer the puppies for both the strom's and Dr's so maybe try both and see how you feel about them as they are not to expensive.
The grip puppies are good but as said make the grip larger may take a bit of getting used to. You can also get grip pussies they are not as thick as the puppies.
Not so much vibration for me, as long distance riding would make my hands numb from maintaining a single position, after years of working with my hands, vibrating power tools, constant pincer grip and pinning various things together while they were fixed it seems I am on the edge of carpal tunnel.
These seem to help, took a little getting used to, feel wise but I've been wearing them regularly for 5 or 6 years now and I will happily buy another pair.
Depending on whether it's the vibration that is the problem or the symptoms you think may be caused by the vibration these may help. Qwi Gloves For Hand Pain & Numbness: Home
Try cycling gloves under slightly oversized unlined 'normal' motorcycle gloves. The main reason being cycling gloves with gel palms are made in vast quantities are really inexpensive and generally better than the niche motorcycle equivalent.
I replaced my grips with Spidergrips. Had tried grip puppies and the were just too ambiguous feeling. The spidergrips do good job at reducing vibs and still giving feedback.
Long story short they are comprised of two layers of rubber. Best grips I have ever owned!
· Vibration Damping Core – This inner layer of material is firmer and has increased durability to reduce the problem of grip twist. Spider engineers have shaped this compound at the boundary layer to reflect and dampen the first waves of vibration.
· Traction Gel – This second layer of material adds tackiness for better holding power, in a special formula which also sheds mud and water. It works to reflect and dampen secondary vibration that may pass through the first layer.
I wore gloves with gel palms for years and they worked fine. Now I wrap my grips with gel tennis racket wrap and it does the job just as good and it doesn't matter which gloves I decide to wear that day.
Related Threads
StromTrooper
1.7M posts
66.6K members
Since 2003
