Heated grips. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
post #1 of 24 Old 04-01-2017, 10:25 PM Thread Starter
Heated grips.
Looking to install some heated grips. My concern is the length of the grips. I really like the Koso grips with integrated controller. They look as though they might be too long. I have Tusk Barkbusters. Looks as though they can be trimmed to about 4.9 inches. Still too long.
Oxford sports look like they can be trimmed down to about 4 1/2. I need about 4.6 to 4.7.
Anyone have any experience with them?
2stroke is offline
post #2 of 24 Old 04-01-2017, 11:04 PM
I've put 4 sets of Oxford touring grips on 4 different 2nd Gen Wees. They are 4.72" long and work great with the Suzuki hand guards. Not sure if there is a difference on your hand guards. I like the Oxfords; nice grips, easy to install, easy to use controller and they work very well.
2thDr likes this.
vstrompat is offline
post #3 of 24 Old 04-02-2017, 02:37 AM
V2man's Avatar
We installed the Oxford Touring heated grips with the Suzuki hand guards.
We have since swapped to Bark Buster hand guards and didn't have to trim the grips with either hand guards.
Cheers
2thDr likes this.
2014 DL1000A 2014 -
2012 DL650L2 2013 - 2014
2007 DL1000 "Bowser" 2009 - 2013
V2man is offline
post #4 of 24 Old 04-02-2017, 05:49 AM
Solo Moto's Avatar
+1 on the Oxford TOURING heated grips for the Vee 2. Oxfords come in three grip styles, with differing patterns, but more importantly, they are all different in length. The Touring grip length is exactly the same as stock grips. Sure, you can trim the longer ones, but why? I put grip puppies over them anyways. One lesson learned, I installed with grip glue,my throttle grip flush with the throttle tube end, lining up perfectly with my Kaoko throttle lock. Worked perfectly until The Oxfords fired up on high heat, expanded from the heat and the friction ring of the Kaoko unintentionally solidly engaged to the point of a safety hazard. Crap. I just removed the Kaoko and called it a day, as I hadn't really used it much over the last 10,000 miles anyways. Have the BarkBuster Storms installed also. Always something to screw up an otherwise perfect install! Ride hard!
Current: '17 R1200GS Adventure, '16 DR650SE, '15 DR200S
Past: '14 DL1000A ADV, '07 DL1000, '01 K1200LTC, '89 ZX10, '81 KZ650, '75 DT400B
Solo Moto is offline
post #5 of 24 Old 04-02-2017, 07:56 AM
Rolex's Avatar
I have oxfords with BarkBusters and the oxfords did not require trimming.
In fact they could have been left longer than the original grips as they fit over the spacers supplied by BB.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #6 of 24 Old 04-02-2017, 09:10 AM Thread Starter
Sounds like oxfords are the way to go. Think I like the sport ones, as they are the shortest. The heat controller is on the left side? Need to figure out where to mount it. Have a switch for LEDs mounted on left side already..... kind of he reason I liked the Koso grips. Very nice OEM look with out a separate controller.
2stroke is offline
post #7 of 24 Old 04-02-2017, 10:58 AM
Rolex's Avatar
The sports are a softer grip, the adventure grips have the holes cut for the hand guards.
The control can go where you like, the left is most convenient for adjusting while on the move.
I mounted mine on the face of the fairing, it is not like you spend much time playing with them so anywhere that you can see them and is within reach will work.
I fitted them directly to the battery as recommended by Oxford and they work as advertised.
If you do decide to trim them, after cutting to the desired length use a grinder to shape the end of the grip for a factory look before gluing in place.
2014 V2, Snoopy
Rolex is offline
post #8 of 24 Old 04-02-2017, 11:00 AM Thread Starter
Good advice. Maybe I'll go with touring then. I'll buy a double perch plate for right mirror from twisted throttle.
2stroke is offline
post #9 of 24 Old 04-02-2017, 11:36 AM
Ron Strommer's Avatar
+1 for for the Oxfords and I can confirm that that "Touring" version is the EXACT same size as the stock grips. NO trimming necessary!
Ron Strommer is offline
post #10 of 24 Old 04-03-2017, 10:03 AM
cwjb's Avatar
I'very got the Kosos with the Bark buster storms. No problems
cwjb is offline
