Voltage Meter Incorrect Reading - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 03-23-2017, 02:52 PM Thread Starter
Swamper's Avatar
We are experiencing on the 2014 Vee our voltage meter indicating the wrong Voltage. It use to always read 14.3 volts while riding. Before starting it read 12.1. About three to four weeks ago it started reading 13.1 and jumps up and down between 12.8 to 13.3 but stays averages the 13.1 most of the time. Before starting it now reads 11.1-11.3. Took it to a battery specialty manufacture and they tested everything, Battery load test as fine in very good condition 12.3 volts. Tested the charging system it was putting out 14.33 at the battery post, all good. Then went to our Suzuki dealer who did the exact same test and noted the exact same results. Both tester technicians said it looked to be a bad voltage meter displaying the information on the bike. Our dealer is going to contact Suzuki about it to see how to correct the reading. Anyone else having this type of problem. Note no accessories are hooked up or being used. We purposely unhooked everything and it didn't make any difference in the readings.
IBA #7147 Current Bikes
14 DL1000ADV
13 DL650A
06 DL650
2004 R1150R, BMW
2002 R1150R, BMW
1996 Road King, Harley Davidson
1994 FXR Superglide, Harley Davidson
Swamper is offline
post #2 of 13 Old 03-23-2017, 03:41 PM
First I'd check the voltmeter negative connections. I always run both the pos and neg for the voltmeter right from the battery posts via a relay.
Second I would connect a digital meter to the voltmeter gauge terminals, put it in a visible place and go for a ride.
09 DL650 Silver
some others
SinNH is offline
post #3 of 13 Old 03-23-2017, 03:56 PM
SECoda's Avatar
Have you added any new electrical components? The more stuff I added the lower it goes on the OEM display but it always stays at least 13.5-13.6 now and doesn't jump around too much. Other voltage readouts I have read above 14v constantly that go directly back to the Eastern Beaver fuse box.
SECoda is offline
post #4 of 13 Old 03-23-2017, 04:24 PM Thread Starter
Swamper's Avatar
It's in the stock dash cluster, not an added on Voltmeter, the new Vee's come with it as a feature.
Coda, All extras have been disconnected from the system. No Accessories what so ever. Testing both way with them hooked in didn't make any difference. Yes when going along with nothing on before at 14.3 turning on equipment would lower the voltage but never down past 13.6. That would be with the heated grips, electric vest and the oiler on.
14 DL1000ADV
13 DL650A
06 DL650
2004 R1150R, BMW
2002 R1150R, BMW
Swamper is offline
post #5 of 13 Old 03-23-2017, 05:10 PM
SECoda's Avatar
Bummer - might be a pain to change.
SECoda is offline
post #6 of 13 Old 03-23-2017, 09:48 PM Thread Starter
Swamper's Avatar
We have the Five year warranty.
14 DL1000ADV
13 DL650A
06 DL650
2004 R1150R, BMW
2002 R1150R, BMW
Swamper is offline
post #7 of 13 Old 03-23-2017, 10:13 PM
SECoda's Avatar
Please let us know if they cover it. They get a lot of bad raps on here on the OEM extended warranty.
SECoda is offline
post #8 of 13 Old 03-23-2017, 11:28 PM
Bugzy's Avatar
That problem sounds electrical to me, as in a loose connection someplace. Maybe your harness is worn through? I assume you had the recall done? Maybe they didn't do it right.
Bugzy is offline
post #9 of 13 Old 03-24-2017, 12:00 AM Thread Starter
Swamper's Avatar
Yes the recall was done and they replace the whole harness.
14 DL1000ADV
13 DL650A
06 DL650
2004 R1150R, BMW
2002 R1150R, BMW
Swamper is offline
post #10 of 13 Old 03-24-2017, 06:56 AM
Henk V's Avatar
Volt meter readings
Well, I cannot tell the exact cause of your bike’s erratic readouts, but my bike’s “stock dash cluster” voltmeter seems to under-read somewhat. When it shows a constant 14.1 – 14.2 Volts on the dash, it is more like 14.6 Volts when I measure it with a digital multi-meter directly on the battery poles. That is without the heated grips (my only added-on electrical accessory) switched on.
Riding since 1995. Previously: Kawasaki KLE500, Suzuki GSX750F and Triumph Tiger 955i
Henk V is offline
