Givi Air Flow Windshield Decal Residue - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 2 Post By Brockie
post #1 of 7 Old 03-18-2017, 06:18 PM Thread Starter
I installed the air flow and on the top section there were 2 givi decals. I removed them as you are supposed to, however it has left a residue.
What should I use to remove it?
I have tried isopropyl alcohol and it did not work.
The warning on the windshield says to not clean with any solution other than water, so I do not want to damage the screen.
Ideas welcome.
Midwinter is offline
post #2 of 7 Old 03-18-2017, 06:25 PM
Goof Off.
Like a champ.
Argus16 is offline
post #3 of 7 Old 03-18-2017, 06:30 PM
WD40 and a microfiber rag
post #4 of 7 Old 03-18-2017, 07:37 PM
bosnjo's Avatar
Gasoline !!!
Cleaned mine in 10 seconds.
2017 DL1000 White
2014 DL1000 Red (sold)
2012 DL650 White (sold)
bosnjo is offline
post #5 of 7 Old 03-18-2017, 07:52 PM
Bugzy's Avatar
googone is a kind of oil/lemon mix, takes that stuff off.
Bugzy is offline
post #6 of 7 Old 03-19-2017, 12:32 AM
I have the Givi Airflow on both bikes. In each case I removed some of the factory stickers. I used Goo Gone (citrus based) on a microfiber towel to remove the residue. No damage to the windscreen.
despling is offline
post #7 of 7 Old 03-19-2017, 04:12 AM
Brockie's Avatar
I realise that the thread is about removing the left over residue but the easiest way is to actually heat the sticker with a hair dryer etc. BEFORE removal and the adhesive will remain on the sticker and the screen (or any plastic surface) will remain pristine.
stu53 and gdrew like this.
Brockie is offline
