loud noise from instrument panel over bumps - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
post #1 of 11 Old 03-06-2017, 05:30 PM Thread Starter
Swlewers's Avatar
I have a 2014 V2. Lately when I hit a good bump I get a loud bang or knock. It is not in the brakes or suspension. I think it is something slapping around in the instrumentation cluster under the wind screen. Much louder if you apply brakes when going over rough pavement. Any one else? IS there a known issue? If so is there a fix?
SL
Swlewers is offline
post #2 of 11 Old 03-06-2017, 05:54 PM
cyclopathic's Avatar
Had similar knock on Wee2 drove me crazy. Actually took plastics and tank off. Turned out extra keys/keychain hitting on a black plastic around lock.
Bugzy likes this.
cyclopathic is offline
post #3 of 11 Old 03-06-2017, 07:24 PM
blaustrom's Avatar
Steering stem bearings loose?
Also the steel frame that holds the whole front instrument assembly is fixed to the frame by 2 bolts that like to get loose. See if there is any play there.
Fox and SECoda like this.
blaustrom is offline
post #4 of 11 Old 03-06-2017, 07:41 PM
SECoda's Avatar
That's a new one for me with a 2014 V2.
I FARKLE'd the heck out of my bike up front with mounts, radar detector, two sets of LEDs, etc. and the dash as well with four new wire harnesses. Also added the crash bars, radiator guard, Givi Airflow - MRC, a camera and two phone mounts plus a dual USB outlet. Still sounds the same.
That is strange. Do you ride a lot of hard off-road?
Front brake? Does it do it with the just the rear brake alone?
"Much louder if you apply brakes when going over rough pavement."
SECoda is offline
post #5 of 11 Old 03-07-2017, 01:41 AM
johno_SLC's Avatar
Check the fairing bolts where they attach to the steering tube. I noticed a lot of vibration (fairing was vibrating up and down) on my first really long ride. I thought it was just the wind, but then later realized one of the two bolts fell out and the other was just a few threads short of joining the first.
johno_SLC is offline
post #6 of 11 Old 03-07-2017, 02:05 AM
Bugzy's Avatar
I can't think of anywhere a fairing attaches to anything related to steering, do you have a picture of that someplace maybe?
I was thinking maybe someone forgot to put the two screws into the front of the gas tank behind the fairings, they are a bit difficult to get to. Maybe the tank is flopping up and down when you hit a bump?
Bugzy is offline
post #7 of 11 Old 03-07-2017, 02:21 AM
Rolex's Avatar
Directly below your ignition switch.
I had one of those bolts come out on me Wee, I was parking the bike at the time and my steering jammed up.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #8 of 11 Old 03-07-2017, 03:38 AM
Ju_Strom's Avatar
Must have been pretty scary, I guess...
Sent from my m2 note using Tapatalk
Ju_Strom is offline
post #9 of 11 Old 03-07-2017, 06:28 PM
Bugzy's Avatar
This is V2 forum. There is nothing in that location except a metal tubing frame that goes forward to hold beak on and maybe some other stuff.
Bugzy is offline
post #10 of 11 Old 03-07-2017, 06:30 PM
blaustrom's Avatar
That's the one. Held by 2 screws. Make sure they are tight and have threadlocker on them.
Bugzy, Rolex and johno_SLC like this.
