Traction control system sensitive - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 2 Old 02-11-2017, 08:07 AM Thread Starter
rgonaut's Avatar
All of a sudden my rear traction control is super sensitive. It's flashes in 2 and a little in 1. It's not very intrusive but flashes mid range.
I took the wheel off a few times(tire and sprocket swap), last time I forgot the abs sensor. I removed it before putting the wheel back on. Looked fine.
Sent from my HTC6500LVW using Tapatalk
rgonaut is offline
post #2 of 2 Old 02-11-2017, 12:34 PM
Bugzy's Avatar
Check the ABS ring for any dents, both front and back. If it gets dented or bent it can throw off the sensors.
I had trouble with my ABS from that before, straightening the ring corrected it.
I have my TC turned off all the time these days, I see little benefit in it.
Bugzy is offline
