Rear Shock Adjusting - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 10Likes
post #1 of 16 Old 02-06-2017, 08:33 PM Thread Starter
pats's Avatar
Is it OK to adjust the shock while not on the center stand? Is it effective if the weight is on the tires?
pats is offline
post #2 of 16 Old 02-06-2017, 09:15 PM
That works fine. If the preload adjuster sticks. it isn't because of the weight on the tires but lack of use. Exercise it regularly. If it sticks, you can take the knob off and use a socket wrench on the nut inside the housing to get more force to break it free.
marcoma and cyclopathic like this.
post #3 of 16 Old 02-06-2017, 09:50 PM
cyclopathic's Avatar
As GW says.
The only time I had issue cranking up preload with pillion in the back. Even then reducing preload isn't an issue. Got the point could adjust without getting off the bike, just stand up.
cyclopathic is offline
post #4 of 16 Old 02-06-2017, 10:03 PM
What's the proper way to adjust suspension? I'm talking proper preload rebound etc
woody071585 is offline
post #5 of 16 Old 02-06-2017, 11:14 PM
Setting preload or sag. 40mm at each end is a good number.
The Science and Black Magic of Suspension Setup
Suspension Adjustment
For rebound damping. If the suspension packs down riding a washboard surface, there is too much rebound damping. If it pogos, there isn't enough.
alfie53, NVDucati and woody071585 like this.
post #6 of 16 Old 02-07-2017, 04:14 AM
I am not very scientific about it I go by balance. I am happy if front and back feel similar going over pothole if one feels stiffer than other than bike will be unsettled - make adjustments.
When preload set and not enough rebound it will feel bouncy and try to kick you up, if too much it feels dead and makes second hit feel harder.. set in the middle.. (usually ends up a compromise on a lighter side for loaded heavier for not as I don't like fiddling with it)
ThatFixedIt and woody071585 like this.
post #7 of 16 Old 02-07-2017, 09:18 AM
Motor7's Avatar
I understand P[pogo, but what do you mean by "packs down" ? Is that when it feels like the Jolly Green Giant has your bike by the tail and is pulling it backwards on the 'boards?
woody071585 likes this.
15 DL650XT
Motor7 is offline
post #8 of 16 Old 02-07-2017, 09:37 AM
He means the same thing the suspension compresses and doesn't return to initial state so second and following hits feel stiffer/too much preload.
post #9 of 16 Old 02-07-2017, 08:39 PM
Motor7's Avatar
10-4....bueno
15 DL650XT
Motor7 is offline
post #10 of 16 Old 02-08-2017, 02:19 PM
rgonaut's Avatar
*rebound, not preload.
The bummer about the rear is that there is only one adjustment. Initially I thought it adjusted both the rebound and compression, but now I need to double check, it may just be the rebound can someone chime in?
Rebound is set to how stiff/slowly you want the oil returning. Set it soft for the suspension to be quicker and stiff to be slower.
Alot of road imperfections, chattering, like a brick road, set to soft, long whoops set to hard.
I set my preload a little higher, I rather top out than bottom out.
rgonaut is offline
