Chain Tension Intervals - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
  • 1 Post By Ago
  • 2 Post By Big B
post #1 of 9 Old 02-02-2017, 04:59 PM Thread Starter
pats's Avatar
I'm new to the chain drive, and seeking an opinon of how often one should worry about checking the chain slack. So if on a trip…every 1,ooo mi. or 1,500mi. Does it depend on the newnwess of the chain sprocket? I ride only on pavement.
pats is offline
post #2 of 9 Old 02-02-2017, 05:06 PM
When you lube the chain, grab it (with a paper towel or gloves if you want to keep your hands clean) at the mid point and check it for tension. Once you've done it with a ruler or tape measure a couple times you'll get a feel for about how much there should be. Excessive slack will be pretty obvious.
V-Strom Ry 2 is online now
post #3 of 9 Old 02-02-2017, 05:16 PM
A chain tends to 'stretch' a little when new. I usually find one adjustment is needed after new then long intervals between adjustments. For example, my bike has about 8300 miles and only one chain adjustment sometime during the first thousand miles. When you find it needing frequent adjustment, it likely is old and time for replacement. DO NOT over-tension the chain. It will wear faster and can cause expensive damage to the bike. I run mine on the loose end of the spec.
2014 DL1000 Khaki
IDRIDR is offline
post #4 of 9 Old 02-02-2017, 06:59 PM
Ago
Ago's Avatar
I adjusted mine during the first thousand miles or so, and then never had to touch it till I replaced the rear tire. I like to run my chain as 'loose & lubed' as I can...
iamsmiling likes this.
Ago is offline
post #5 of 9 Old 02-02-2017, 09:41 PM
STCorndog's Avatar
All the above is correct/good info and my experience also. But, I check my chain and tires daily. Now only tires ;-)
STCorndog is offline
post #6 of 9 Old 02-02-2017, 09:44 PM
swingset's Avatar
Send a message via Yahoo to swingset
Don't run it too tight....the spec in the manual is suspect (IMHO), run it to the looser side of that if you must. Tight chains wear fast and require frequent adjustment.
swingset is offline
post #7 of 9 Old 02-02-2017, 11:55 PM
I adjust mine when I change tires. With lube and steady hand a chain should't wear excessively.
post #8 of 9 Old 02-04-2017, 06:16 AM
I'm with others who have said they keep their drive chains on the looser end of spec. Too loose though and I find gear changes begin to feel more jerky. It doesn't take much to adjust the chain back to its happy place - often only a 1/4 turn of the bolts.
dovetailredux is offline
post #9 of 9 Old 02-04-2017, 07:03 AM
Once initial stretch occurs, typically no further adjustments are needed for the longevity of a rear tire.....perhaps longer.
Al Pal and notacop like this.
