Trickle charge thru Power-Let 2014 DL1000 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
post #1 of 13 Old 01-05-2017, 04:26 PM Thread Starter
pats's Avatar
I installed a power-let port on the side plastic to plug-in my heated vest.
When not using the vest, is it possible to use a trickle charger/maintainer with the matching male power-let plug, to reverse the power feed, and keep the battery charged in winter? My 2002 BMW had a similar factory set-up but I am unsure if what I did is identical.
pats is offline
post #2 of 13 Old 01-05-2017, 04:29 PM
I did that on my last Strom and worked like a charm.....assuming your powerlet is going straight to your battery?
post #3 of 13 Old 01-05-2017, 04:34 PM Thread Starter
pats's Avatar
I know the positive lead is directly to the positive battery post, but unsure if the negative is to the negative post or to the frame for ground, would this matter?
pats is offline
post #4 of 13 Old 01-05-2017, 04:41 PM
You don't ever want to ground to the aluminum frame of these bikes, go straight to the battery or a dedicated grounding block which would obviously go to your battery! I have an EB PC8 so I use that for all my switched or unswitched power needs.
SECoda likes this.
post #5 of 13 Old 01-05-2017, 04:54 PM Thread Starter
pats's Avatar
OK, will take a look at that.
pats is offline
post #6 of 13 Old 01-05-2017, 06:55 PM
Why would you not ground through the aluminum frame?
blz2dwl is offline
post #7 of 13 Old 01-05-2017, 06:55 PM
blaustrom's Avatar
You should have your powerlet at least fused. If that is the case and it's attached directly to the battery (not via switched power) than you can attach your trickle charger that way. Make sure the polarity is correct.
Alternatively, if you have a battery tender, they normally come with an SAE pigtail connector for the battery and for the tender. That is what I use, zipped to the passenger foot peg bracket. Also useful to operate a tire compressor (if you have one). If you want to do use that setup, make sure the fuse rating is suffizient for the mini compressor since the fuse for just running the tender is I think only 5A. It will blow when you operate the compressor.
Big B likes this.
blaustrom is offline
post #8 of 13 Old 01-05-2017, 06:57 PM
blaustrom's Avatar
It can cause an electrochemical element and potentially corrode your Al frame. Use only copper wires for both hot and ground connections.
Big B, iamsmiling and SECoda like this.
post #9 of 13 Old 01-05-2017, 07:07 PM
Solo Moto's Avatar
Lightbulb
Yup - I have installed a powerlet port off my sub frame for my heated vest. I cut off excess wiring and the inline fuse and connected direct to the EB PC8 to an unswitched circuit (allowing charging), and have the adapter to plug in my battery tender. Slick setup, no drilling my plastics, easily removed and serves a dual purpose.
Powerlet Type-1 Rearset Kit - RevZilla
Current: '17 R1200GS Adventure, '16 DR650SE, '15 DR200S
Past: '14 DL1000A ADV, '07 DL1000, '01 K1200LTC, '89 ZX10, '81 KZ650, '75 DT400B
Solo Moto is offline
post #10 of 13 Old 01-05-2017, 10:06 PM Thread Starter
pats's Avatar
EBPC8 where do I find? guess I should upgrade.
pats is offline
