Cold weather starts - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 9Likes
post #1 of 14 Old 12-15-2016, 01:29 PM Thread Starter
pats's Avatar
Cold weather starts
I got the "freeze" light when starting the strom at 34f. Just doing this to keep the battery up in the cold shop. Is it too cold and hard on the engine to do this without a preheat?
pats is offline
post #2 of 14 Old 12-15-2016, 01:33 PM
V-Tom's Avatar
Nope. Start the engine and ride away, although gently at first.
..Tom
My Opinion:
Vee or V= DL1000 before 2014
Vee3 or V3 = DL1050 2020 to?
My Stroms:
SMIDSY detailed report.
V-Tom is offline
post #3 of 14 Old 12-15-2016, 01:45 PM
Do not idle the engine to warm it up or charge the battery. It causes excessive engine wear to idle cold and creates acids in the oil. Only start the engine if you are going for a ride and ride it right away, keeping the revs under 5000rpm. The engine warms up faster under the light load of riding under 5000rpm until it gets warm enough to rev higher. Get it good and warm and the condensation and water created by combustion boils off so acids are not created by byproducts of combustion dissolving in water. If you aren't going to ride long enough to boil the water off, probably a minimum of 30 minutes or so, don't start the engine. For sure don't idle it. If you are worried about the battery, top off the charge with a battery tender once a month. The battery discharges extremely slowly in cold weather though so it isn't really necessary.
Big B, OydnaR and ernieD2 like this.
post #4 of 14 Old 12-15-2016, 02:13 PM
OydnaR's Avatar
My winter rule is
" if it takes longer to get dressed than the time of the ride, I take my Jeep"
I'll ride 100 miles in zero degree weather, but not 8 miles
greywolf, stu53, K9 Wee and 1 others like this.
IBA#9560
Copyright (c) 2019
OydnaR is offline
post #5 of 14 Old 12-15-2016, 02:53 PM
V-Tom's Avatar
Originally Posted by OydnaR View Post
My winter rule is
I suspect that 8 miles of riding usually takes more than 8 minutes,
Does it really take you that long to get dressed for riding?
..Tom
My Opinion:
My Stroms:
V-Tom is offline
post #6 of 14 Old 12-15-2016, 04:24 PM
OydnaR's Avatar
..Tom
In the winter when I'm dressing for 0°f,yes
my typical errand, going to the post office, is a7˝ miile round trip
I can run the errand in my Jeep completely quicker tha I can be dressed and ready to leave the driveway on my bike
IBA#9560
Copyright (c) 2019
OydnaR is offline
post #7 of 14 Old 12-15-2016, 07:13 PM
STCorndog's Avatar
I disagree with some here. When its down around the mid 30F range, I let my bike idle a minute or two. Then I shut it off, put it in first, pull clutch in and restart. Now I am ready to ride. I do this to warm the clutch up a little and avoid the big clunk from shifting into first with a cold and draggy clutch pack.
Idling a minute or two harms nothing. I do agree that its best to ride at least a half hour or more in the cold and not do very short trips. I also like synthetic oil for cold weather use. In the car I do the same thing except the turn off/restart step.
STCorndog is offline
post #8 of 14 Old 12-15-2016, 07:31 PM
My V2 doesn't have a stiff cold clutch, but the KLR certainly does. My solution is to put in 2nd gear and push it with the clutch lever pulled in to free the sticky clutch plates. Works great.
2014 DL1000 Khaki
IDRIDR is offline
post #9 of 14 Old 12-15-2016, 07:53 PM
STCorndog's Avatar
Its not fun to push a Super Tenere. After first shift, she is smooth as silk. I forgive her for it.
post #10 of 14 Old 12-15-2016, 10:17 PM
If you aint gonna ride it......don't start it.
greywolf and K9 Wee like this.
