One for the brains trust...... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 23Likes
post #1 of 21 Old 12-11-2016, 02:10 AM Thread Starter
Stromaholic's Avatar
Here's a curly one..... 2014 Vee2. Mods - Arrow collector, Yosh can, XTRE, DNA air filter, other chassis mods are not applicable. Filled fuel tank yesterday and headed off for an overnighter, less than 5 kms down the road the motor gave a massive hiccup like the kill switch was turned off and on again, the ABS light flashed slowly 3 or 4 times but the bike kept going and ran perfectly for the next 70 odd kms, then did the same thing again 4 or 5 times in the space of around 500 metres. Once again, the ABS light flashed slowly while this was happening, pulled the clutch in and the motor stalled, released the clutch and the motor re- started. Not prepared to get caught without phone service, I turned for home and pulled over where I could. Checked all electrical connectors I could get to and found nothing obvious, so started the bike and rode back home without any problem. Once home, I hooked up to the OBD tool and no fault codes were displayed and all values were within factory parameters. Gave the bike a thorough inspection and found nothing untoward, rode around 150km today and the bike ran flawlessly. Any ideas???
Never argue with an idiot.......they drag you down to their level, then beat you with experience!
Stromaholic is offline
post #2 of 21 Old 12-11-2016, 02:26 AM
Sgt Schultz's Avatar
Don't know if it's possible wth fuel injection but sounds like an air lock in the fuel system?
But don't trust in my brain
Stromaholic likes this.
I know nuffink, I see nuffink, It was not me, I was not here.
IBA #45920
FarRider #299
2015 Wee Strom "Piglet"
Givi crash bars, Barkbusters, Ravetech Bash plate, Ravetech Rad guard, Ravetech over dash Ram mount, Hyperlite flashing brake lights, Madstad bracket and screen, Augustus wind deflectors, Spot 3, UHF two way radio, Garmin Zumo GPS, Starcom intercom, Fuze block.
SW Motech Centre stand, Suzuki power outlet. Bike Alarm, Screaming Banshee horn, Led Flood lights, Tool tube, Andy Strapz Expedition soft panniers and frames.
Sgt Schultz is offline
post #3 of 21 Old 12-11-2016, 03:37 AM
Sounds more electrical. The first thing to try is to tighten the battery terminals.
post #4 of 21 Old 12-11-2016, 04:03 AM Thread Starter
Yes, first check was that, all good
post #5 of 21 Old 12-11-2016, 04:32 AM
SECoda's Avatar
Ever had bad gas (water in gas)? Just a WAG.
SECoda is offline
post #6 of 21 Old 12-11-2016, 04:36 AM
That isn't it. The ABS light antics indicate low voltage in the system, at least intermittently. Also check the battery ground at the engine case. That is part of the recall.
post #7 of 21 Old 12-11-2016, 09:33 AM
V-Tom's Avatar
Has the recal work been done?
..Tom
richlandrick and Stromaholic like this.
My Opinion:
Vee or V= DL1000 before 2014
Vee3 or V3 = DL1050 2020 to?
My Stroms:
SMIDSY detailed report.
V-Tom is online now
post #8 of 21 Old 12-11-2016, 09:36 AM
Did you have recall done? Maybe chaffed wires under tank or ignition switch are causing a short?
2stroke is offline
post #9 of 21 Old 12-11-2016, 09:38 AM
Definitely sounds like an electrical issue. Which can be many different things to check. There is a recall as mentioned, and this was to correct the harness from rubbing and causing an intermittent short. Which sounds like what you have? Beyond that I would be checking connectors and the ground wires like greywolf mentioned.
realshelby is offline
post #10 of 21 Old 12-11-2016, 12:18 PM
NVDucati's Avatar
Time passes by
Our batteries in the 2014 bikes are creeping up on being 4 years old. Heck, mine was 2+ years old before its first mile. I know that on my BMW the battery seemed okay (volt meter =12.5) but it was not passing the bike's test circuit. This is evidently known in the beemer service departments. Obviously, I can't know that this applies here. (Occam's Razor)
Member: AMA
NVDucati is online now
