Aftermarket Fuse Block - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 7Likes
post #1 of 14 Old 12-10-2016, 12:08 PM Thread Starter
pats's Avatar
I have just added accessory wires to the battery posts. Anyone used the black fuse block . Is there anything cheaper, perhaps BluSea, than the one from Japan?
pats is offline
post #2 of 14 Old 12-10-2016, 12:46 PM
SECoda's Avatar
I have the EB PC-8 but have used all of the six switched circuits. I am looking to drop in the Blue Sea 12 maybe and to reuse the EB relay/harness for $40 as I have read a few have done. The Blue Sea 12 is a bit bigger but it fits in the 1000. It has outstanding reviews as well as the EB and Denali. It supports 30A per circuit. I think motorcycles are the main use from the reviews. 3.32"W x 5.2"H x 1.52"D
https://www.amazon.com/dp/B001P6FTHC?ref=emc_b_5_i
https://powerwerx.com/blue-sea-5029-...LzMaAtz08P8HAQ
I looked at:
Blue Sea 12 ($40 no harness)
Centech ($50 no harness)
Fuzeblock ($90 no harness)
Denali ($129 w/ harness)
Eastern Beaver CP-8($65 no harness - $108 w/ harness)
SECoda is offline
post #3 of 14 Old 12-10-2016, 12:55 PM
RCinNC's Avatar
You could try something like this, from O'Reilly Auto Parts (I'm sure Advance, Autozone, etc have the same type parts):
BWD FB90 - Fuse Block | O'Reilly Auto Parts
I can't tell the amp rating on the block from the website, but it probably says so somewhere on the package. It's made for automobiles, so I imagine it's fine for bikes. Not as convenient as the Eastern Beaver PC8 (which is what I have), but it is cheaper. However, unless you want it to always be hot, you're going to have to make a relay for it. Amazon has automotive relays and relay sockets for as low as about 5 dollars each....maybe lower, I didn't do a lot of searching.
Centech makes a fuse panel for about $56.00, available from Amazon.
https://www.amazon.com/Centech-AP-2-.../dp/B003H2486K
I've read reviews in the past about the Centech that complained that the fuses were loose in their holders, but that may have been corrected; the current reviews seem favorable.
RCinNC is online now
post #4 of 14 Old 12-10-2016, 01:09 PM
Jim L's Avatar
I used the Blue Sea 5025, I think I paid $27, it's too large to fit under the rear side covers, but it fits in the tray under the seat just fine. For me, the six circuits is plenty. Just add a relay, some wire, connectors and your ready to go.
SECoda likes this.
Jim L is offline
post #5 of 14 Old 12-10-2016, 01:32 PM Thread Starter
pats's Avatar
I don't understand the need for a relay. My aftermarket led lights have a relay and I also have the heated grips which I think have a relay inline. My power outlet for heated gear goes directly to the battery. What does the relay do?
pats is offline
post #6 of 14 Old 12-10-2016, 01:34 PM
Jim L's Avatar
The relay shuts off the fuse block with the ignition switch
Jim L is offline
post #7 of 14 Old 12-10-2016, 01:39 PM Thread Starter
pats's Avatar
Thanks for the great comparison SECoda
pats is offline
post #8 of 14 Old 12-11-2016, 06:41 PM
TAC PRO's Avatar
The BlueSea block is compact and robust and made from good quality materials. It makes for a neat installation with only one additional wire on each battery terminal.
If you want switched circuits, you would have to add a relay between the battery and fuse block. https://www.stromtrooper.com/maintena...ml#post2829993
SECoda and NVDucati like this.
Spaling errors and typos have been included on porpoise for those who enjoy finding them.
www.tacpro.com
TAC PRO is online now
post #9 of 14 Old 12-11-2016, 06:51 PM
SECoda's Avatar
I think I will make all 12 circuits switched on the relay. I have a direct Battery Tender jr power cord that I can use for the tire air compressor I carry. I power everything (except the Sena on my helmet) and most devices I have are very low current like two phones and two cameras (front/rear). The Garmin Zumo GPS doesn't use much or the Cobra radar detector (under beak). The two sets of LEDs (Denali DR1s and MondoMotos on crash bars) draw a little more but that is eight devices right there. I am using two double port USB power sources. One front and one rear besides the 12V outlet. No heated things. I have AdMore LED lighting in the Givi V47 but it adapts into the tail light wiring directly. There are three add-on relays. I guess I like gadgets. You should have seen the instrument cluster on my little homebuilt light sport airplane.
SECoda is offline
post #10 of 14 Old 12-11-2016, 07:13 PM
ltljohn's Avatar
If you do not need more than 3 circuits the 3 circuit from Eastern Beaver is a well built and reliable.
3 Circuit
ltljohn is offline
