Front Brake Shuddering - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 11Likes
post #1 of 12 Old 12-06-2016, 08:50 PM Thread Starter
mjt57's Avatar
I bought a used V-Strom 1000. It's got 24,000 km or around 14,000 miles on it.
The previous owner had it serviced before I purchased it. However, since I've owned it now for a couple of weeks I've noticed a rather harsh shuddering under braking, particularly heavy braking.
Just wondering if this is a natural occurance for this beast. If not is it a common problem? It can be either brake pads, warped discs or head stem bearing adjustment/wear.
Work to ride, ride to work...
mjt57 is offline
post #2 of 12 Old 12-06-2016, 09:07 PM
texastromrider's Avatar
Heavy braking? Does it have ABS? If it does perhaps it's engaging.
texastromrider is offline
post #3 of 12 Old 12-06-2016, 10:00 PM
With 14K on those brake pads, they "may" be pretty worn.
post #4 of 12 Old 12-06-2016, 10:10 PM Thread Starter
mjt57's Avatar
No, not that. I lightly squeeze the lever and you can feel back through it.
In any case, I've already tested the ABS out. It's nothing like this.
mjt57 is offline
post #5 of 12 Old 12-06-2016, 10:28 PM
Sounds like you have a warped disc, or pad build up on disc. Try scrubbing disc with a scotch Brite pad.
richlandrick, Toto and iamsmiling like this.
2stroke is offline
post #6 of 12 Old 12-06-2016, 10:41 PM
Yes I agree. Does the wear on the discs look uniform? If your disc is warped you might see an area of the disc that isnt as worn as the rest.
post #7 of 12 Old 12-06-2016, 10:45 PM
NVDucati's Avatar
Very high probability that it simply has brake pad material stuck to the rotors. It builds up and forms "waves" like whoops on a motoX track. It is hard to scrub off. There is no magic chemical. But with enough elbow and Scotch Brite they will return to new.
Someone will tell you that you have warped rotors. Nearly impossible on a modern Japanese street bike. Don't accept that diagnosis easily. Don't have the rotors "turned". Just clean them.
Sorry if I sound a bit strident ... it can be avoided if the brake pads are allowed to cool down for the last mile or two before you park it. If for some reason you can't cool them, at least try to avoid clamping the front brake as you park. That is the point where the material gets bonded to the rotor.
Big B, richlandrick, Toto and 1 others like this.
Member: AMA
NVDucati is offline
post #8 of 12 Old 12-07-2016, 02:39 AM
Bugzy's Avatar
I use my front brake more than my rear and just switched out my front pads at 24k km, they did not need to be switched yet, I could have gone another 10k km on them easily.
This video is good showing how easy maintenance is on these, you could pull the pads out, clean the whole thing out with a toothbrush, and apply some high temp grease, that might clear up your issues.
Another thing to do is get the front wheel off the ground, and give it a spin to see if the rotors are warped or lumpy.
richlandrick and mjt57 like this.
Bugzy is offline
post #9 of 12 Old 12-07-2016, 06:12 PM
Rolex's Avatar
If your disc is warped your brake lever will also pulse as the calliper cylinder moves in and out.
Brockie likes this.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #10 of 12 Old 12-07-2016, 08:52 PM
Brockie's Avatar
If you do take the brake pads out for inspection machine them flat again by finding a nice flat piece of concrete path and buff the pad material using a circular motion.
Warning - using a piece of concrete often walked by your loving partner may result in domestic disharmony.
Brockie is offline
