V2 Won't Start! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 28Likes
post #1 of 121 Old 11-13-2016, 04:59 PM Thread Starter
NyMeTsFaN912's Avatar
V2 Won't Start!
I just finally got my V2 back together since the accident. Went to start her up and no cranking but full power. Checked the fuses and they all seem good. Any ideas?
-John
NyMeTsFaN912 is offline
post #2 of 121 Old 11-13-2016, 05:04 PM
Does it turn over and not fire, or nothing like the starter is not turning?
Sent from my SM-G900V using Tapatalk
Jeremiah Still is offline
post #3 of 121 Old 11-13-2016, 05:19 PM Thread Starter
I repeat no cranking but full power.
-John
post #4 of 121 Old 11-13-2016, 05:25 PM
Stromtrooper.com Sponsor
richlandrick's Avatar
John,
The statement is not as clear as you think. What do you mean by full power?
No cranking = will not turn over with starter?
Check the clutch switch.
NyMeTsFaN912 likes this.
richlandrick is online now
post #5 of 121 Old 11-13-2016, 05:31 PM
Originally Posted by richlandrick View Post
John,
Kickstand switch, neutral switch. Lights should dim when starter button is pressed? Fuel pump will cycle if all of the above switchs are working.
post #6 of 121 Old 11-13-2016, 05:43 PM
The side stand switch and kill switch will show a CHEC on the display. The neutral switch can only be a problem if there is also a side stand switch problem. The clutch lever switch will just cause the starter motor not to spin. The headlight will go out when the start button is pressed, not just dim. The start switch is almost never a problem except with the headlights. The starter contacts only activate a relay and are very lightly taxed. 99% of the time, the symptoms described with no CHEC displayed are due to the clutch lever switch.
post #7 of 121 Old 11-13-2016, 05:49 PM Thread Starter
I'm thinking it's the starter switch since it was pretty dirty from the accident. When I press it the headlight shuts off as it normally does. If the starter switch was bad would it still kill the headlight when depressed?
No chec or anything out of the ordinary. The bike has full power and just won't crank. I checked the clutch switch and the wires were connected and fine. The fuel pump primes and when I turn the throttle makes a whining sound.
Before I pulled the bike apart the bike ran absolutely fine. Something went wrong between disassembly and assembly.
-John
post #8 of 121 Old 11-13-2016, 05:51 PM Thread Starter
Tomorrow morning before work I will try to mess with the clutch switch connectors again. I had to change my handle bars because they were bent so I had the wiring and levers hanging off to the side and they were moved around often. I can see this disturbing the wiring but since I checked the connectors and they were still firmly connected I don't know what else to check on the clutch switch.
-John
post #9 of 121 Old 11-13-2016, 06:05 PM
bosnjo's Avatar
Run one wire between negative on battery and one of the screws visible on the metal bracket between the seat and the tank (visible with seat removed). If the bike starts, you have broken "ground" connection wire.
Jeremiah Still likes this.
2017 DL1000 White
2014 DL1000 Red (sold)
2012 DL650 White (sold)
bosnjo is offline
post #10 of 121 Old 11-13-2016, 06:10 PM Thread Starter
I'm not sure I understand that. How would that allow the bike to start?
-John
