What size is the oil plug on this bike? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 11-13-2016, 03:53 PM Thread Starter
num
I may have stripped my pan (totally forgot i was working with aluminum and i was a little heavy handed)
I'm going to get a timesert for it, but i can't find the plug size.
num is offline
post #2 of 7 Old 11-13-2016, 05:16 PM Thread Starter
num
Is it M14 x 1.25 x 12mm ?
Can anyone confirm ?
num is offline
post #3 of 7 Old 11-13-2016, 09:24 PM
flgolfer29's Avatar
I can't say for certain. In the service manual I only see tightening torque specs for the plug, size not listed
Sent from my SAMSUNG-SM-G930A using Tapatalk
Last edited by flgolfer29; 11-13-2016 at 09:27 PM. Reason: Edited to add: I've had better luck finding that part from on-line parts searches
flgolfer29 is offline
post #4 of 7 Old 11-14-2016, 10:55 PM
My notes say M12 x 1.25. Make sure the new drain plug head clears the outside bend in the pan. I made that mistake.
Sent from my SCH-I545 using Tapatalk
Cryoman is offline
post #5 of 7 Old 11-14-2016, 11:07 PM
You have a 650. The 1000 uses an M14x1.25
post #6 of 7 Old 11-15-2016, 03:06 AM
You can also buy self tapping drain plug inserts. They typically have an inner that's smaller but they are easier to use.
i.e. LOTS and LOTS of people have made this mistake and there's a premade cure
PeteW is online now
post #7 of 7 Old 11-15-2016, 12:01 PM Thread Starter
num
Thanks for the confirmation, I just spent 20 bucks on a caliper to make sure.
I'm going to do a writeup on the time sert install. There doesn't seem to be one for this bike.
num is offline
