Trekker Outback vs Dolomiti? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
post #1 of 31 Old 11-01-2016, 09:53 PM Thread Starter
RCE1's Avatar
I was just getting ready to get some new bags for my DL1000A and had pretty much decided on the Trekker Outback cases and CAM racks ordered form Italy. Now I see there's a new series, the Trekker Dolomiti. I like the silver aluminum finish, but I wonder whether I'd regret not getting the Outback cases. I've not seen the new series in person, but the pictures look good. I was planning to get a 48L and 37L combo, but I think the Dolomiti series is only available in 36L. I don't do any super long distance touring any more, but do like the look of aluminum boxes and the utility of top opening. The Suzuki cases just feel a little cheesy to me and I really don't care for the side opening and latch design.
Anybody see the Dolomiti bags in person?
RCE1 is offline
post #2 of 31 Old 11-02-2016, 05:13 PM
I liked the dolomiti cases. I had a look at them in a shop a while back and was going to get a set, then I discovered the kappa k venture panniers. Just like the trekkers but cheaper. I came off the other day on some mud and they took the fall with only a scratch on the corner and a very slight dent. Hardly any damage so they get my vote.
Grahamdermagraphica is offline
post #3 of 31 Old 11-02-2016, 05:22 PM
This was the pannier that I landed on. I was doing 25 mph in tarmac. No real damage. I was amazed.
post #4 of 31 Old 11-02-2016, 05:54 PM
VstromGrin's Avatar
Hi what top case is that you have on and is there any issue with the top opening lid on the panniers hitting the top case?
any chance you might have a pic from the rear of the bike?
wondering how much clearance there is between the pannier and top case. I have an e55maxia top case which is 590mm or 23.2" approx. wide.
I looked at the Dolomiti as well, I think the Kappa Kventure are a bit more robust though,
and like that the corners are protected by the plastic pieces.
2013 SUZUKI DL650 AL2
VstromGrin is online now
post #5 of 31 Old 11-02-2016, 08:12 PM
jgonzo's Avatar
So the Kappa's mount the same as the Givi's?? Same boxes just cheaper?? How or why does this happen if the same company makes both? Isn't that just cutting your own throat for the more expensive line?? I don't get it......
Garage......
Oh Yea: '17 Aprilia Tuono Factory
'14 DL1000
'02 Daytona 955ce
'87 ZL1000
'85 &'86 ZL900's
jgonzo is offline
post #6 of 31 Old 11-02-2016, 09:59 PM
VstromGrin's Avatar
I think they are what you'd call sister companies,kappa isn't that much cheaper, just that these kventures and Givi dolomiti mount on the existing monokey racks, (using the supplied adapter kit)
but the Givi trekker outback require the cam side racks.
Bugzy likes this.
post #7 of 31 Old 11-04-2016, 05:00 AM
Yeah. I didn't do my homework and ordered cam side racks only to find they didn't fit. But they are stronger than standard givi racks, so I bodged them to allow the k ventures to fit.
No problems with opening them when my maxima top box is on.
File Type: jpg 1478246360182-149659536_1478246379530.jpg (94.2 KB, 123 views)
File Type: jpg 1478246392589622426032_1478246405265.jpg (95.2 KB, 96 views)
post #8 of 31 Old 11-12-2016, 11:48 AM
VstromGrin's Avatar
Have you found anything that will utilise the space underneath the pannier lid? I see Givi supply a net for the purpose, part no. Givi E144
bit expensive for what it is, I 'd like to get some kind of pouch maybe velcroed under the lids, it would take a lot of the small crap I carry in the tank bag. Haven't figured out what to do with it yet, k venture panniers won't be here till next week.
post #9 of 31 Old 11-16-2016, 02:20 PM
TeeBone's Avatar
bicycle shops have cargo nets that will work in the Givi lids for like 6 bucks. Not a perfect fit but fine for the use. I have the givi Trekker Outbacks 37L and really like them. survived several tip overs with no damage. Got them for a steal at probably the same Italian web site mentioned here.
TeeBone is offline
post #10 of 31 Old 11-17-2016, 02:44 AM
VstromGrin's Avatar
Got my K ventures and fitted them yesterday, no problem with the left pannier lid opening with the e55 top box fitted,there is plenty of clearance, delighted with them, love the top loading,I'll look into some way of storing stuff under the lid,
I came across some other brand of pannier that had a liner for under the lid with dif zipped pouches in it,must have a look to see if I can find it again.
