Chain life on V2 - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 100Likes
post #11 of 103 Old 10-26-2016, 03:18 PM
alon's Avatar
Originally Posted by V-Tom View Post
I would love to know how it works out for you... that is how long the chain lasts. From what I have understood (but not tried) the chain oilier should keep the chain well lubed and should help the chain to last a long time. In theory probably longer than what I do.
From what I have read, the specs on RichlandRick's Tutoro Chain oiler sound really good and if I wasn't so lazy I would probably try one out.
..Tom
i have had it for about 3.5k and it worked great!
although just about a 2 weeks ago i noticed that it stopped oiling even though it shows like it is (when i prime it it works ) i need to disconnect it from the battery for an hour but didn't have time to deal with it right now
2014 vee2- OEM:skid plate,heated grips,mirror extenders,centerstand. aftermarket:sw-motech: risers,trax 45L side cases 38L top case,pipe valve guard, kickstand foot enlarger. corbin/holshot heated seat ,MRA VarioTouringScreen,burkbusters storm,PC8, kaoko throttle lock, scorpion titanium slip-on, denali airbomb,scottoiler,denalli dx.pc5+autotune R&G:radiator guard, pipe slider K&N:air filter touratech:crashbars, ABS kill switch,dryspec tool tube,cyclops LED headlights,doubleback mirrors,helmet guardian,twowheels shorty levers,aftermarket off road rear brake lever,shorai lithium battery.
alon is offline
post #12 of 103 Old 10-26-2016, 04:17 PM Thread Starter
V-Tom's Avatar
Originally Posted by Big B View Post
That Wurth lube aint cheap, would be over $30 shipped........it aint that good.
Ouch!
Last I looked it was under $20 Canadian $.
I have been told that the frequency of lube is the main key though so perhaps other products might give similar results.
..Tom
2015 DL1000 New July 2015 175,000+ km, 108,500+ miles.
SMIDSY detailed report.
V-Tom is offline
post #13 of 103 Old 10-26-2016, 04:39 PM
Sgt Schultz's Avatar
I have ordered a Cameleon oiler. Has had good reviews even against the Tutoro and Scottolier.
Should come any day so will post up pics and give a review soon as I can.
Big B, V-Tom and despling like this.
I know nuffink, I see nuffink, It was not me, I was not here.
IBA #45920
FarRider #299
2015 Wee Strom "Piglet"
Givi crash bars, Barkbusters, Ravetech Bash plate, Ravetech Rad guard, Ravetech over dash Ram mount, Hyperlite flashing brake lights, Madstad bracket and screen, Augustus wind deflectors, Spot 3, UHF two way radio, Garmin Zumo GPS, Starcom intercom, Fuze block.
SW Motech Centre stand, Suzuki power outlet. Bike Alarm, Screaming Banshee horn, Led Flood lights, Tool tube, Andy Strapz Expedition soft panniers and frames.
Sgt Schultz is offline
post #14 of 103 Old 10-27-2016, 02:59 PM Thread Starter
V-Tom's Avatar
Your price above shocked me so I called Wurth Canada. The price for a single can has gone up.. it it $19.71 per can if purchased by itself and if in a case of 12 it would be around $17 or $18. These are Canadian Prices in Canadian Dollars and should be quite a bit less in the USA. It isn't sold at retail stores but is sold direct by Wurth. Many Auto dealerships use it so it is possible your local dealership may have some.
We go through cases of it at our dealerships.
(I have no affiliation with Wurth and just think they make a great product.)
..Tom
V-Tom is offline
post #15 of 103 Old 10-27-2016, 03:13 PM
PerazziMx14's Avatar
I recently bought a second hand Scott oiler and after 2,000 miles and about 3.5 ounces of ATF my chain is clean and lubricated. I'm happy enough that if another used auto oiler (any brand) pops upat a reasonable pirice i'll grab it and put it on one of the other chain driven bikes.
V-Tom likes this.
PerazziMx14 is offline
post #16 of 103 Old 10-27-2016, 04:56 PM
swingset's Avatar
Send a message via Yahoo to swingset
I barely get 20k out of good chains. They're not overtightened, they're lubricated every gas tank or more.
The problem is I ride dirt. Every chance I get. Dusty gravel, mud, the kind of stuff that sticks to wet lube and creates a grinding paste.
Dirt kills chains, and you must clean them. Can't just re-lube a chain caked in sticky muck. If you don't clean 'em, you'll just be recreating the grinding paste when you re-wet the grime and gunk that's caked in between the plates, that goes to the rollers, chain wears out. Even if you don't clean them, the trapped gunk creates corrosion and that'll take its toll too. Sprockets, too, they go fast when you're riding dirt.
I could stop riding so much dirt, but no chain life is worth that.
Big B, V-Tom, VSrider and 2 others like this.
swingset is offline
post #17 of 103 Old 10-27-2016, 07:06 PM
SECoda's Avatar
I just spoke to a long time rental dealer in Wisconsin visiting family and he said the grit must come off or the rentals oring chains won't go 10k miles. They use Bel-ray since dirt doesn't stick to it. The trails here are all gravel and dirt. He says he has tried everything over decades on dozens of bikes. I am using Dupont Chainsaver so am not promoting the product. My dealer in Missouri uses Bel-ray as well concidentally. I may try it.
SECoda is offline
post #18 of 103 Old 10-27-2016, 08:20 PM
swingset's Avatar
I've tried Belray, Teflon-products, wax-based lubes, even went for spells where I just didn't lubricate with anything. Dirt sticks to it all, if you get into enough dirt and the right kind. Dust, especially from clay roads & gravel, is insidious...it just coats your whole driveline.
I found that after riding dirt, I had to clean the chain prior to re-lube pretty much no matter what I did.
The hardcore dirt guys, GNCC racers and the like swear by WD-40 or really light lubes for that sort of thing. Dirt sticks to it, but it flings off, cleans and re-lubes (a little bit) about as well as anything else. I carry some when I ride dirt, and hose the chain down on my way home....tends to make the cleanup at home a lot easier.
swingset is offline
post #19 of 103 Old 10-28-2016, 08:30 AM
chirosyd's Avatar
It makes sense and I agree with the posts here including Vtom, Swingset and those who advocate for automatic oilers. I currently use Motorex off road lube, and am happy with the product. I lubricate the chain after the second tank fill ( more or less if I have a CRS moment). I clean my chain when the dirt accumulates with a cloth soaked in oil or degreaser.
That said, personally, I have a different approach. When the chain and sprockets tick off about 25,000 miles, I proactively have them replaced regardless. 25,000 miles takes me about two plus years into the parts, and for the $$, I am happy to ride the bike new again. For $200., I have peace of mind, a ride to rely on with no worries.
chirosyd is offline
post #20 of 103 Old 10-28-2016, 03:16 PM
NVDucati's Avatar
Chain Guard
IF I was regularly using my V2 in the dirt, I would certainly modify the chain guard. Namely, the inside needs to offer coverage for the chain from the dirt that gets piled on it from the rear tire.
The OEM chain guard is sort of a minimalist bikini item. In the past (on enduro bikes) I have used a length of rubber from the kick-space at the bottom of kitchen counters to keep the dirt and mud off in the first place. A few pop rivets and a heat gun. It also helps keep the countershaft sprocket area from packing up. All the info in the previous posts still apply.
V-Tom and Sgt Schultz like this.
Member: AMA
NVDucati is online now
