Has anyone replaced the stock 7/8" bars with pro-tapers or something else? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 10-18-2016, 07:35 PM Thread Starter
I'm looking for suggestions for new bars? Anybody have and suggestions? I was think Pro-taper ATV high bend with Rox risers.
2stroke is offline
post #2 of 11 Old 10-18-2016, 08:18 PM
This...
https://www.stromtrooper.com/showthread.php?t=232897
Post #61
Sent from my XT1254 using Tapatalk
2015 DL1000 ADV
2thDr is offline
post #3 of 11 Old 10-18-2016, 08:19 PM
Easy as. Bend and style is going to be a personal choice sort of a deal. What works for me may not for you. Need to sort the mounting when you get adaptors. Need a little nounce and lateral thinking to sort out depending.
Tom R
can email you picks of my set up if you pm an address
"No Fear" just means you are not going fast enouh yet. life begins when you get outside that comfort zone.
Current rides
18 Busa
14 Vee2
13 Husky TR 650 Terra
08 Busa(now sold)
07Vee1(now sold)
02 Busa (sold)
97 TLs
97 TRX
92 NSr
Current Projects
38 BSA Goldie
Upcoming projects,perhaps by the time I get retired just maybe
83 GSX11(gunna be bought forward now as I don't have a going across frame 4)
71 A100
tomrux is offline
post #4 of 11 Old 10-18-2016, 08:40 PM Thread Starter
Originally Posted by 2thDr View Post
This...
Post #61
I want the fat bars though. Thank you for the link.
2stroke is offline
post #5 of 11 Old 10-18-2016, 08:42 PM
Brockie's Avatar
I replaced my stock bars with Pro-Taper ATV mid seven eigths. The height is almost identical. The bars are probably 2 inches wider and I am sure that the extra leverage has saved me from falling at least once while riding on gravel roads https://www.youtube.com/watch?v=C0x4325uKW8 (grabby brakes locked the front wheel). The ends of the bars are marked so they can be easily and accurately shortened if desired. The bars compared to stock do not bend inwards as much, tending to keep your elbows out.
Brockie is offline
post #6 of 11 Old 10-18-2016, 11:54 PM
Protaper atv high
ThumpinA2Z is offline
post #7 of 11 Old 10-19-2016, 09:56 AM Thread Starter
What kind of risers did you use?
2stroke is offline
post #8 of 11 Old 10-19-2016, 03:40 PM
I did the fat bars with the shorter Rox risers.
I like the flexibility in finding the sweet spot for me.
PM me an email addy I will sent pics, posting them here is a PITA.
A signature
sdmdm8 is offline
post #9 of 11 Old 10-19-2016, 09:14 PM
decaman's Avatar
For $29.99 these Tusk T-10s couldn't be beat. I had to adapt the bar end expander bolt with a piece of rubber hose, but the new position relieved a lot of wrist stress. I originally had 2" ROX risers but the hi bend was sufficient so I removed them.
https://www.rockymountainatvmc.com/p...8%22-Handlebar
decaman is offline
post #10 of 11 Old 10-20-2016, 01:44 AM
I installed Pro-Taper EVO - Adventure Bars (part # 024026) these are the 1 1/8 inch bars. I cut 1/2 inch off each end - just because for me a better hand position. I mounted them with Rox-Elite 2 inch Pivot Risers for 7/8 or 1 1/18 handlebars (Rox part # 1R-P2SEK). Keep in mind that the Pro-Taper Evo Adventure bars have 14mm ID NOT the 18MM standard. So standard OEM bar ends will not fit. This set up is just perfect for me. The lines including the front brake line is at its stretch limit. I kept the cables & clutch/brake lines in front of the tripple tree just like stock, but have removed the line brackets at the yoke to free up more play. I am able to rotate the handlebars completely to the right & left. I installed bark buster hand guards, with necessary modifications in order to get them to fit properly along with a Kaoko Throttle lock. The fitment process for the bark busters & throttle lock is a bit complicated keeping in mind this set up is custom. So, I can't go into all of the adjustments I made to get them to fit simply because it will take me to write an instruction sheet. But if you are very comfortable with tools, a little custom work, you should do fine.
z-faucon is offline
