Few questions on mods to the strom - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
post #1 of 13 Old 10-10-2016, 10:26 PM Thread Starter
DasTwitcH's Avatar
So I got a beakstrom finally after lusting after them forever. Beautiful piece of work. I'm after some extras for it though, and wondering if you guys can give me some input on best way to go, if even possible:
Bar ends - looking at a few options, but most bar ends seem pretty plain. Is the strom a standard 7/8ths or 1inch?
Frame Sliders - looking at the Puig ones coz they don't look like hockey pucks. Anyone had experience with them?
Fuel tank filler - is it possible to replace the tank ring without replacing the filler cap? I want a black outer ring to match the black filler cap rather than the silver it has now.
Low beam headlight - is it possible to adjust the LOW BEAM without taking off the dash? I read here that you can adjust the high beam with a long driver, and I've felt out the screw for that...but from what I can see the low beam is hidden behind the tacho...
DRLs - has anyone found home installable DRLs and/or LED headlights for the beaky?
Gear shifter - is waaaaay too far in towards the bike for my giant feet. Is there an easy way to widen it out so I'm not twisting my leg sideways to get a toe onto it? or do I just go for the motech extendable?
Thanks for your patience guys. I know it's a lot of questions at once but I've been trawling the forums and google for a while now and i'm getting a little....braindead.
DasTwitcH is offline
post #2 of 13 Old 10-10-2016, 10:44 PM
Hanz's Avatar
I can only try to help with your last question - I don't have experience with the others.
You can use this to extend your shifter also. <-Click it for a link
That's made by an innovative forum member.
richlandrick likes this.
Hanz is offline
post #3 of 13 Old 10-10-2016, 10:48 PM Thread Starter
DasTwitcH's Avatar
I've seen his page the problem is that's extension away from the peg. I need extension sideways away from the body of the bike...
post #4 of 13 Old 10-10-2016, 11:45 PM
Yah, that head light thing... I think there are 2 screw that make the lights go up and down. I'se got the 1st version (an '04). The bulb has the high and low filament so any adjustment will affect both.
I did the E Beaver wiring and the light are brighter but still low on the roadway.
If you want a black filler ring, take it off and paint it.
post #5 of 13 Old 10-10-2016, 11:47 PM Thread Starter
DasTwitcH's Avatar
WHY THE HELL DID I NEVER EVEN CONSIDER THAT????
Thanks dude I'll do that.
post #6 of 13 Old 10-11-2016, 12:03 PM
I'l expect a commission on the savings of a can o' paint vs what one of those fancy rings costs.
post #7 of 13 Old 10-11-2016, 12:17 PM
Note the forum involved. Vee2s have separate high and low beam lamps.
post #8 of 13 Old 10-12-2016, 01:20 PM
Stromtrooper.com Sponsor
richlandrick's Avatar
Our gear shift relocation kit moves the gear shift out slightly more than 1/4 from the bike. Check out the thread here to see what those large of foot and those using motorcross boots have said about it.
https://www.stromtrooper.com/adventur...elocation.html
richlandrick is online now
post #9 of 13 Old 10-12-2016, 02:36 PM
If you paint the gas cap trim ring be sure to use paint that won't dissolve when gas spills on it.
azrid'n is offline
post #10 of 13 Old 10-12-2016, 06:53 PM
swingset's Avatar
Send a message via Yahoo to swingset
You can raise the shift lever so that your foot gets under it easier. That might help.
swingset is offline
