How hard is it to take a Sync Reading. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 5Likes
post #1 of 18 Old 10-05-2016, 02:48 PM Thread Starter
ToadRide's Avatar
I got the wifi sync tool now but I am not ready to tear everything apart. Still riding. Can I just lift the tank to find the vacuum nipples or do I have to go for covers removal, tank removal?
ToadRide is offline
post #2 of 18 Old 10-05-2016, 05:22 PM
V-Tom's Avatar
Smarter minds than mine will answer but I believe I have read that there is no real point in synchronizing the 2014+ DL1000 unless you have the full electronic diagnostic equipment and even then it only affect idle.
(However I may be wrong.)
..Tom
My Opinion:
Vee or V= DL1000 before 2014
Vee3 or V3 = DL1050 2020 to?
My Stroms:
SMIDSY detailed report.
V-Tom is online now
post #3 of 18 Old 10-05-2016, 07:15 PM
I don't know if this link will work for you but check it out. DL1000A (L4) SERVICE MANUAL
The instructions specify how to use the Suzuki SDS tool. You'll have to check the HealTech Suzuki OBD tool instructions for how to lock/set the ISC valve when using it.
It says the fuel tank needs to be lifted and the air box taken off.
Disconnect the IAP sensor vacuum hoses (1) from the throttle body.
Connect the respective vacuum tester hoses (1) to each vacuum nipple on the throttle body.
Equalize the vacuum of the cylinders by turning each synchronizing screws (1) and keep it turning at idling speed. NOTE: Always set the engine speed at idle speed.
pvwheeler and richlandrick like this.
post #4 of 18 Old 10-05-2016, 07:59 PM Thread Starter
ToadRide's Avatar
VTom. I have read a couple of times that the sync is not always perfect from the factory. Having too much time on my hands and also being hundreds of kms from the nearest dealer I decided to do it...'for the Halibut'.
GW. I am now set up with all the necessary tools including one fat shop manual that arrived last week. I fully know how to tackle it and it may happen this fall or next spring. My question was can I get to the vacuum nipples by simply lifting the tank. Then I can just plug in the wifi sync gauge and see whats what.
V-Tom and richlandrick like this.
ToadRide is offline
post #5 of 18 Old 10-05-2016, 08:05 PM
You don't have free vacuum nipples like the older bikes did. You have to take the hoses from the IAP sensors off the throttle body. The manual says you need to take off the airbox but the manual has said things that were wrong before. See if you can get at the hoses and air screws and you can tell us.
post #6 of 18 Old 10-06-2016, 09:49 PM
Let us know how it goes. I just picked up a used HealTec and am interested in trying this out over the winter.
blz2dwl is offline
post #7 of 18 Old 10-07-2016, 06:58 AM
pvwheeler's Avatar
I did mine and noticed a difference at low rpms. seems smoother.Both my older Vees were very sensitive to throttle body sync.My DL650s not so much.
I will do mine again this winter. Not sure if you can do it without removing the airbox...not with my hands for sure ! LOL
2015 Wee2 EXP "Arya"
2002 DR650 SM "Tormund"
2014 CB500x (wifes)
2018 XT 250 (wifes)
pvwheeler is offline
post #8 of 18 Old 10-07-2016, 10:19 AM
PVWheeler, did you use the Healt ech USB device to sync?
blz2dwl is offline
post #9 of 18 Old 10-07-2016, 10:51 AM
pvwheeler's Avatar
Yes.
Sent from my SM-G900W8 using Tapatalk
2014 CB500x (wifes)
2018 XT 250 (wifes)
post #10 of 18 Old 10-07-2016, 11:17 AM Thread Starter
ToadRide's Avatar
you still need gauges to sync, not just the Healtech. I bought this.
Bluetooth Android Wireless Throttle Body Sync Tool, 2 Cylinder Model | eBay
ToadRide is offline
