Preload adjuster - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By Brewers Whoop
post #1 of 2 Old 09-01-2016, 03:53 PM Thread Starter
Brewers Whoop's Avatar
Preload adjuster
The preload adjuster on my '14 is solidly stuck. I found Vlads excellent 'how-to' on sorting the adjuster on previous models, but the adjuster is different on the Vee2 (although the internals may be the same). The adjuster is integral with the top of the shock, and the knob does not have any clearly visible means of removal.
Anyone done a refill or rebuild of the Vee2 adjuster?
Brewers Whoop is offline
post #2 of 2 Old 09-21-2016, 11:13 AM Thread Starter
Sorted! WD40 and determination shifted it. It was set 11 clicks from fully 'soft', which I understand is the factory setting. So I suspect it had nevewr been altered since new, and two years worth of crud and winter had jammed it tight. Regular soakings of WD40, and this morning it moved, and now turns readily with visible movement of the spring cap. Chuffed.
Bugzy likes this.
