V2 Valve check/adjust questions - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
post #1 of 22 Old 08-28-2016, 05:13 PM Thread Starter
I'm getting ready to do my first valve check/adjust on my 2014 DL1000A. I have experience adjusting shim-under-bucket valves, so I don't expect any problems.
A couple of questions:
Can someone verify for me that the V2 uses 9.48 mm valve shims as were used in the previous DL1000?
Does anyone who has done a valve adjustment on this bike have any hints, warnings or advice about what to watch out for? Ways to make things easier (bodywork/tank removal or anything else)?
I have a shop manual, which looks pretty comprehensive.
Thanks,
Michael
michael95453 is offline
post #2 of 22 Old 08-29-2016, 12:01 PM
Remove as much of the body work as able to just make your life easier.
You will also have to drain the coolant to be prepared to do that as well in order to get to the front Cyl.
Also this is a very good time to dielectric grease all the plugs etc you are able to get to.
Depending on the mile replacing the plugs might be a good idea, if nothing else grease the plug boots and whatnot because over time they get stuck in the heads a little and tear when you remove them.
I would spray WD40 into the sparkplug well before removing anything the help prevent tearing of rubber. Just a couple shots and wiggle stuff around abit so it can work itself in there.
Dont go crazy with it..
A signature
sdmdm8 is offline
post #3 of 22 Old 08-29-2016, 09:51 PM
ToadRide's Avatar
Thanks,
Michael
How many miles?
ToadRide is offline
post #4 of 22 Old 08-30-2016, 12:02 PM Thread Starter
Originally Posted by ToadRide View Post
How many miles?
15,000 miles; 20 months since new.
post #5 of 22 Old 08-30-2016, 12:27 PM
ToadRide's Avatar
I would not bother. I think you would find at 50000 miles, not much would have changed.
ToadRide is offline
post #6 of 22 Old 08-30-2016, 12:51 PM
This is the first check though. Until that is done, changed from what? You need the first check to get an idea of where things are to begin with. The first check is the most important and 15,000 miles is the time to do it. Once it is done, you'll know how close to minimums the settings are and get an idea as to how long until the next check is needed. 9.48mm is the correct size.
Big Mike 2009 likes this.
post #7 of 22 Old 08-30-2016, 10:12 PM
cwjb's Avatar
Is this any different than the valve adjustment on the V1 ?
cwjb is offline
post #8 of 22 Old 08-30-2016, 11:45 PM
Getting the tupperware off is different but the engine work looks to be the same.
post #9 of 22 Old 08-31-2016, 10:29 AM Thread Starter
I don't consider it a bother to maintain my bike.
post #10 of 22 Old 08-31-2016, 10:32 AM Thread Starter
Thanks greywolf, for the straightforward, non-judgmental, informative answer.
