Healtech piggyback - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 08-19-2016, 06:50 PM Thread Starter
fig
fig's Avatar
Healtech piggyback
Anybody use one of these? Not real clear what thenadvantages are. Seems to just remove rev limiter.
HealTech Electronics Ltd. - X-Tre Power Box
fig is offline
post #2 of 3 Old 08-19-2016, 07:15 PM
Stromtrooper.com Sponsor
richlandrick's Avatar
Your bike uses timing retardation to limit power while in some gears. The TRE (Timing Retard Eliminator) eliminates this limitation. I suggest using the search function and reading up on "TRE."
There is a lot said about it on VSRI also. You can get a TRE without buying the gear indicator. Since the Vee2 already has a gear indicator a stand alone TRE makes more sense.
richlandrick is offline
post #3 of 3 Old 08-20-2016, 05:56 AM
bosnjo's Avatar
I have one on mine. It has to be "X-TRE" model to keep the gear indicator working. "TRE" model will dissable the gear indicator.
I can't say if I realy need it anymore. I installed it when I first got the bike, back in 2014. The low speed ride was rough, a lot of surging, sometimes stalling... After I installed X-TRE, all of the problems were 90% gone. I didn't care much about speed limiter. I used 5th gear map (after testing other possibilities). Then, one year later, came new ECU and my dealer replaced it with no questions asked. New ECU solved everything by 100%, that X-TRE had solved by 90%. Now I still have both on the bike but I guess X-TRE is now there for nothing, except for removing speed limiter but as I still have it 5th gear map, I guess speed limiter is there as only 4th gear map removes it.
Just too lazy to remove it from the bike now.
2017 DL1000 White
2014 DL1000 Red (sold)
2012 DL650 White (sold)
bosnjo is offline
