MIVV carbon oval install help... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
post #1 of 16 Old 08-16-2016, 12:05 AM Thread Starter
The connector pipe seems either too small ID or has too short of a flange. With lubricant I cannot get it closer than 11/16 ths from going completely on. Anyone have any suggestions? Thanks!
Sent from my XT1254 using Tapatalk
2015 DL1000 ADV
2thDr is offline
post #2 of 16 Old 08-16-2016, 10:12 AM Thread Starter
Any tips? Can a muffler shop "stretch" the connector pipe larger? I was thinking not?
2015 DL1000 ADV
2thDr is offline
post #3 of 16 Old 08-16-2016, 04:49 PM
Bugzy's Avatar
Ice on the inside pipe, and heat up the muffler pipe, then push together?
Maybe a little sanding of the inside pipe?
Bugzy is offline
post #4 of 16 Old 08-16-2016, 07:47 PM
Bad Dad's Avatar
I'd bring it to your local muffler shop, mine fixed this in no time!
2002 DL 1000
Bad Dad is offline
post #5 of 16 Old 08-16-2016, 07:54 PM
NVDucati's Avatar
They can easily make it larger.
They can just as easily make it too large.
Take the whole bike not just the new muffler. Personally I'd use a hot rod exhaust shop as opposed to a franchise replacement shop.
Vhawg likes this.
Member: AMA
NVDucati is online now
post #6 of 16 Old 08-16-2016, 08:52 PM Thread Starter
What grit and type? Black 200 grit wet/dry? Heat on connector pipe sounds easy enough. What about anti-seize on the connection?
2015 DL1000 ADV
2thDr is offline
post #7 of 16 Old 08-16-2016, 10:21 PM
fig
fig's Avatar
Dry ice on the male end, mapp gas on the female. Let the dry ice sit on it for about 20 minutes. AutoZone or the like will have a tail pipe expander for loan but be careful not to go too big. Check out YouTube for guidance. If you aren't comfortable with the above take it to a muffler shop.
I dunno if I'd try anti seize. Maybe some WD 40.
If I was gonna try sand paper id use some emory cloth and tear a long thin strip, then wrap it around the male side 1.5 times and pull each end back and forth. This way you remove the same amount of material evenly. Just do a little at a time then try the fit until it goes on. It should be a tight fit anyway. Are you putting enough elbow grease on it when you try?
fig is offline
post #8 of 16 Old 08-16-2016, 10:33 PM
ToadRide's Avatar
Just torch the slip on pipe. It will expand and should slip right over.
Vhawg likes this.
ToadRide is offline
post #9 of 16 Old 08-17-2016, 08:54 AM
It's Italian . Once you get it all the way in ....trust me...you will be VERY happy.
Slow Eddie is offline
post #10 of 16 Old 08-17-2016, 06:10 PM
fig
fig's Avatar
Yeh that should work fine.
Vhawg likes this.
fig is offline
