DON'T BUY SW-MOTECH top case adapter !!!!!! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 15Likes
post #1 of 56 Old 08-02-2016, 10:46 AM Thread Starter
alon's Avatar
After multiple times of the bolts shearing off and replacing every thing from the bolts to the whole kit i finally had a long talk with the twisted throttle tech
so basicly what he told me that it's really a crappy design but no other options because of the way the rear rack is designed on the vee2
the new rack is designed to carry up to 16lb(compared to 23lb with the old vee) including the case (which weighs about 10lb) so that means that the bolts are already at about 2/3 of the max load when it's empty and to that some bumps and it can easily snap the bolts. still a crappy design. he told me to try again and only torque with a screw driver (even though i used a torque wrench ) so i make sure it's not over torqued .
and to take it off when off roading .
basicly dont use it for any mildly rough stuff!!(and even means rough asphalt like NYC has)
my conclusion DON'T BUY SW-MOTECH top case adapter !!!!!!
and maybe anything else they make. because why would you release such a shitty product even if there is nothing you can do to improve it!!!!!????
2014 vee2- OEM:skid plate,heated grips,mirror extenders,centerstand. aftermarket:sw-motech: risers,trax 45L side cases 38L top case,pipe valve guard, kickstand foot enlarger. corbin/holshot heated seat ,MRA VarioTouringScreen,burkbusters storm,PC8, kaoko throttle lock, scorpion titanium slip-on, denali airbomb,scottoiler,denalli dx.pc5+autotune R&G:radiator guard, pipe slider K&N:air filter touratech:crashbars, ABS kill switch,dryspec tool tube,cyclops LED headlights,doubleback mirrors,helmet guardian,twowheels shorty levers,aftermarket off road rear brake lever,shorai lithium battery.
alon is offline
post #2 of 56 Old 08-02-2016, 11:40 AM
trapperdog's Avatar
What about switching to higher grade bolts?
'09 VEE
'07 HD SEUC
'09 ST1300P
'06 ST1300
trapperdog is offline
post #3 of 56 Old 08-02-2016, 11:45 AM Thread Starter
alon's Avatar
well he said the reason they use these bolts is to make sure they snap before tweaking the subframe
alon is offline
post #4 of 56 Old 08-02-2016, 12:06 PM
V-Tom's Avatar
The (Metal) Givi topcase mount works brilliantly with no issues.
I have had it since I got this 2015 DL1000 a year and 50,000 km/31,000 miles ago. I routinely ride on very rough roads, often load my 6 year old Givi E52 topcase with way too much crap, and not a single issue.
..Tom
Bad Dad, Snownut, Skew and 1 others like this.
SMIDSY detailed report.
V-Tom is offline
post #5 of 56 Old 08-02-2016, 12:20 PM
NyMeTsFaN912's Avatar
I had the aluminum SWM top case adapter on the 2015 XT I sold and had no issues and purchased the SWM steel top case adapter plate for my 2015 DL1000 and never had a problem with that either. I'm thinking you're doing something wrong or you had a bad batch of bolts.
Brojon likes this.
-John
NyMeTsFaN912 is offline
post #6 of 56 Old 08-02-2016, 01:14 PM Thread Starter
alon's Avatar
the problem is only with the vee2 (and i am not the only one who had this problem )not the xt.
I Have replaced the bolts about 7 times
i replaced the rack twice.
i did the install and so did my tech.
now i can understand you saying i did something wrong ,but so did my tech!?
have you been doing any off roading with your bike?
are the roads in edison as bad as manhattan?
alon is offline
post #7 of 56 Old 08-02-2016, 05:43 PM
I don't take it off road but yes, NJ has bad roads. I see what you're saying and just assume they had a batch of bad bolts. I don't know what else to make of it.
-John
post #8 of 56 Old 08-02-2016, 07:25 PM Thread Starter
alon's Avatar
the TW tech pretty much told me that the options how to mount a case on the vee2 suck so that's the best the could do
i am thinking of changing to touratech but its a lot of $$$$ to shell out after i already did on the SWM
alon is offline
post #9 of 56 Old 08-02-2016, 08:17 PM
fig
fig's Avatar
Just throwing tho out there.....when I was on the Concours Owners Group, it was very common to make your own top case adapter using nylon or plastic cutting boards. We would just drill hole to mount one to the bike then drill hole in another one the same, place one inside the top box sandwiching it inbetween the two cutting boards. Crude but very effective. It's also fixed so can't be pulled off without unbolting. Painted or stained them black. Just a thought. I wouldn't hesitate to do this to my bike if I didn't already have a box mounted and tbh it's just a cheap Chinese box I've been swapping on other bikes for about 4 years now....lol. Works great though. Best $40 I ever spent.
fig is offline
post #10 of 56 Old 08-02-2016, 10:11 PM
Bad Dad's Avatar
..Tom
This is the solution.
V-Tom, Snownut and Bugzy like this.
2002 DL 1000
Bad Dad is offline
