2014 DL1000 w/Holeshot-Corbin and SWMotech Steel Plate - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 07-24-2016, 07:30 PM Thread Starter
PhilS14's Avatar
Hello group
Bought Dale's seat and love it! Took a 400 mile ride through Ohio twisties the weekend it arrived and it felt perfect, even when hanging off. Outstanding quality.
Issue - It is a couple inches longer at the rear end and it pushes up against the SWMotech steel plate used for the rear case. I am having to trim about a half inch or more off the plate for all to be well and for the plate not to run into my new seat and cut it.
PhilS14 is offline
post #2 of 9 Old 07-25-2016, 09:59 AM
alon's Avatar
i have both and the fit fine (its a tight fit but it fitts )
https://1drv.ms/f/s!AifsKL4SKbi1iR0J5R_3enGFvWnQ
2014 vee2- OEM:skid plate,heated grips,mirror extenders,centerstand. aftermarket:sw-motech: risers,trax 45L side cases 38L top case,pipe valve guard, kickstand foot enlarger. corbin/holshot heated seat ,MRA VarioTouringScreen,burkbusters storm,PC8, kaoko throttle lock, scorpion titanium slip-on, denali airbomb,scottoiler,denalli dx.pc5+autotune R&G:radiator guard, pipe slider K&N:air filter touratech:crashbars, ABS kill switch,dryspec tool tube,cyclops LED headlights,doubleback mirrors,helmet guardian,twowheels shorty levers,aftermarket off road rear brake lever,shorai lithium battery.
alon is offline
post #3 of 9 Old 07-25-2016, 11:30 AM Thread Starter
PhilS14's Avatar
Mines tight too. Just figured rubbing over time would hurt the $400 seat!!
PhilS14 is offline
post #4 of 9 Old 07-25-2016, 12:25 PM
alon's Avatar
well i had dave's first seat and i have thousands of miles on it and it's fine
alon is offline
post #5 of 9 Old 07-26-2016, 11:43 PM
Buszzbait's Avatar
Whats the difference between Dales Corbin seat vs getting it from Corbin?
2014 Vstrom DL1000
2010 HD FLHTK Ultra Limited
2006 Vstrom DL1000
2000 HD Softail Classic
Buszzbait is offline
post #6 of 9 Old 07-27-2016, 11:50 AM
alon's Avatar
it's a little lower and is more tapered towards the tank.
basicly dave took the corbin design modified it and corbin is making them for him
alon is offline
post #7 of 9 Old 07-27-2016, 11:24 PM
Buszzbait's Avatar
Thanks..Good to know
2014 Vstrom DL1000
2006 Vstrom DL1000
post #8 of 9 Old 07-28-2016, 09:16 PM Thread Starter
PhilS14's Avatar
Cured. Cut about 1/2" away and a little black paint to keep it from rusting. All better.
PhilS14 is offline
post #9 of 9 Old 07-28-2016, 10:16 PM
NyMeTsFaN912's Avatar
I bought the same seat with the same top rack and had the same exact issue. I ended up taking a grinder and ground it down just enough so it clicks in now. Works just fine.
-John
NyMeTsFaN912 is offline
