Factory OEM tall seat for a 2016 DL650? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 07-24-2016, 10:31 AM Thread Starter
Rocketman 2012's Avatar
Is there one available?
I need a little more leg room and have thought about lowered footpeg brackets like I've put on a lot of past bikes but although the gear linkage looks easy to adjust, the rear brake not so much so and as it is, I have to lift my foot off the peg to use the rear brake so another inch lower would make it worse, hence the thought of a taller seat.
If so, where to buy?
Thanks!
Sam
Carthage, Missouri 64836
Rocketman 2012 is offline
post #2 of 6 Old 07-24-2016, 12:19 PM
I have both the OEM seat and Suzuki Gel seat for the newer DL650, and the Gel is clearly taller, maybe 1/2", perhaps a bit more. Not sure if the difference is sufficient for you, but the Gel is more comfortable as well.
For more money, the Adcox would be a better solution, as its taller and significantly more comfortable than either OEM or Gel, based on what I have read here.
mpom is offline
post #3 of 6 Old 07-24-2016, 02:05 PM
BCSTROM's Avatar
BCSTROM is offline
post #4 of 6 Old 07-24-2016, 02:23 PM
Originally Posted by BCSTROM View Post
Even with the $25 installation fee, seems like a good deal!
mpom is offline
post #5 of 6 Old 07-24-2016, 05:33 PM
York's Avatar
650 high/low seat
Originally Posted by Rocketman 2012 View Post
Is there one available?... hence the thought of a taller seat...If so, where to buy?..Thanks! Sam
Hi Sam,
here in the DL1000 thread you might not get the amount of feedback you are looking for.
Nevertheless Suzuki offers OEM high and low seats for your 650.
Link here OEM Parts : Babbitts Suzuki Partshouse
(listed after the grip heater)
York is offline
post #6 of 6 Old 07-24-2016, 06:03 PM
Number_6's Avatar
I know you asked about 650.
I can confirm that moving pegs down 1" (25.4mm) and
using the Tall OEM seat, adding about the same in height..,
is much easier on my old knees at least...can slide back more in
the seat which is great for longer arms.
I will use the Tall OEM seat for my '14 DL 1000A and
maybe just keep the standard OEM to experiment with
using air cushion or sheepskin....anyway I like the extra
2" or so ... easier on the knee position for long rides.
Just my observation but confirms your previous mods for better ergos.
Good luck finding a taller seat.
V65 Magna, VMax, B-King, Vee2.
Number_6 is offline
