Slight oil leak on right side. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 07-16-2016, 07:05 PM Thread Starter
Pulled my skid plate off to change oil and noticed there was a little oil residue on right side. The drain bolt and oil filter were dry. Looks like it is coming from a little 4" rubber hose below water pump on crankcase. I think I might of put a bit too much oil in on last fill up. Does anyone know if this is an overflow? I would of thought if u put too much oil in, it would blow by and come out air filter box.
Any ideas?
2stroke is offline
post #2 of 4 Old 07-16-2016, 08:20 PM
That's the puke tube from the water pump. It originates at the #3 dual seal. Either coolant or oil will run out of the tube if the seal fails on one side.
post #3 of 4 Old 07-16-2016, 10:00 PM Thread Starter
So my seal is failing on water pump?
2stroke is offline
post #4 of 4 Old 07-16-2016, 11:08 PM
Either that or a bit of foreign material is trapped at the seal edge.
