Oil indication acting weird - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 7Likes
post #1 of 29 Old 06-04-2016, 08:35 AM Thread Starter
What do you think?
https://youtu.be/foNyRK4-CpM
nikolas is offline
post #2 of 29 Old 06-04-2016, 10:03 AM
For sure. You should be getting a steady red light with the engine not running. You probably have a sensor problem.
post #3 of 29 Old 06-04-2016, 01:29 PM Thread Starter
Sometimes is steady sometimes it is not..but this time i managed to capture it on video because Suzuki wouldnt believe it
nikolas is offline
post #4 of 29 Old 06-08-2016, 02:38 PM Thread Starter
Anyone having similar issue?
nikolas is offline
post #5 of 29 Old 06-09-2016, 01:32 AM
kustard's Avatar
Yeah my 2014 does that occasionally. I told the service guys when I last got it serviced and they checked it out but couldn't find anything unusual and typically it didn't play up when they had the bike. I just keep an eye on the oil level before and after each ride and might do a video of it (good idea btw) and show them next time it's in for service.
Suzuki DR650 (2016) - Grey
Yamaha XSR900 (2016) - Blue
Sadly deceased: Suzuki VStrom DL1000 (2014) - White
Shiro Suzuki shijūha~tsu 白スズキ四十八 (White Suzuki forty-eight)
The Adventures of 69SIM - https://www.youtube.com/channel/UCzK0IIM_4zZjC3DF95GIBKA
kustard is offline
post #6 of 29 Old 06-09-2016, 11:00 PM
Grimmer's Avatar
You also had a moment (@ 0:13 - 0:22) when the display read "CHEC" and your temperature indicator was all the way up. Also the gear position and traction control info disappeared. Perhaps a dashboard connector or engine harness problem? Seems to be affecting more than just the oil light/display.
Grimmer is offline
post #7 of 29 Old 06-09-2016, 11:44 PM
The CHEC would be from the kill switch or sidestand switch being in a non running position. I'm sure the OP did it purposely and was aware of it. The temp bars fill up to direct the rider's attention to the CHEC. It has nothing to do with heat. Everything I saw was expected for someone using the kill switch to shut off the engine except the flashing oil light.
post #8 of 29 Old 06-10-2016, 12:25 AM
randyo's Avatar
study up on your Morse Code, the bike is trying to tell you something IUT?
nikolas likes this.
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #9 of 29 Old 08-12-2016, 12:34 PM Thread Starter
That s right, i was trying to show the problem and intentionally lowered the side stand
nikolas is offline
post #10 of 29 Old 08-12-2016, 12:36 PM Thread Starter
It would be really usefull in my opinion if you could as well capture it, because it may not be just a single case (on mine) as it seems.
nikolas is offline
