ABS Fuse Pulled - Traction Control Light On. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
post #1 of 20 Old 05-23-2016, 11:04 AM Thread Starter
Zig-Zag's Avatar
I went riding off road for the first time with 3 other riders. I pulled the 15 amp ABS fuse and the traction control light came on so I assume it was also disconnected. The speedometer read zero mph while moving, and after a while the fuel injection light came on. While still moving I pulled the clutch in, shut off the engine and re-started. The fuel injection light went out but re-lighted several times later and I would repeat the procedure. When we were finished riding off road I replaced the fuse and everything returned to normal.
I have a few questions - Is this normal for a '14 V2?
I saw a video on how to disconnect the ABS but it was for a 650 Strom. How can I turn off the ABS and still keep my traction control from turning off? I'm pretty good at electrical, so wiring isn't a problem for me.
Is the fuel injection light and speedometer acting up normal?
Ride it like you're invisible - Because you are.
Bikes past and present:
1967 Honda 305 Superhawk - Sold
1976 Honda 750 Superhawk - Sold
1978 Velorex sidecar added
1978 BMW R90 (with the sidecar) - Sold
2003 Kawasaki 1600 Vulcan - Crashed
1986 Honda 700s Nighthawk - Sold
2005 Suzuki S50 - Sold
2012 Victory Cross Roads - Keeper
2014 Suzuki DL1000A - Keeper
Zig-Zag is offline
post #2 of 20 Old 05-23-2016, 11:49 AM
Some threads on the subject.
https://www.stromtrooper.com/dl1000a-...heel-spin.html
https://www.stromtrooper.com/dl1000a-...tched-abs.html
post #3 of 20 Old 05-23-2016, 01:35 PM
RickB1975's Avatar
You can put the bike on the center stand. Shift into 2nd gear and let out the clutch. After a few seconds the ABS will shut off. It will turn back on when you shut off the key and turn the bike back on. I've done this a few times and had no problems, however there doesn't seem to be much of a need to shut off the ABS, even off-road.
RickB1975
RickB1975 is offline
post #4 of 20 Old 05-23-2016, 01:49 PM
Snowlover's Avatar
This subject interests me. Lots of "True Adventurers" rag on ABS. I watch some video of a BMW bounding down a hill out of control because ABS was on. My question of that video was "how about gearing?" No way that BMW guy was in a gear, most likely the clutch pulled in during the panic or shifted to Neutral.
I am not a hot dog off road rider, but so far have done minor testing of front ABS while controlling speed coming down gravel roads. I activated ABS a couple of times and knowing it would come on, found it helpful finding the max amount of front brake to use without wash out.
Basically, i just don't understand the hatred for ABS unless you are hard core, brake sliding corners and such.
Anyone have Strom knowledge of the advantage of tuning ABS off?
V-Tom and cheapbastard like this.
So many roads, so little time !
Snowlover is online now
post #5 of 20 Old 05-23-2016, 02:17 PM
well I cant speak to the video but I can tell you there were more than one occasion when off road that the ABS made it impossible to control downhill decent using the brakes. Major pucker factor.
Traction control at the high setting makes getting up lose hills also tough.
Really depends on the terrain. For me in my area there is lots of sand and loose surface so those two factors which make ABS and Traction Control both risk factors for me on this bike off road. Once again this is purely my experience.
A signature
sdmdm8 is offline
post #6 of 20 Old 05-23-2016, 02:25 PM
There are times when off pavement I want to skid.
MY V2's ABS works MUCH better than my buddy's BMW ABS in the nasty. His will run away on him.
My plan is centerstanding and running up the rpms a little in 2nd gear to kill abs in bad spots. It's good to practice with and without it.
2thDr likes this.
2014 DL1000 Khaki
IDRIDR is offline
post #7 of 20 Old 05-23-2016, 02:49 PM
alon's Avatar
you should pull the ABS pump fuse not other abs fuse (because i think it kills the ABS the sensor which also is part of the tc and speedometer ).
this should solve all of the problems
2014 vee2- OEM:skid plate,heated grips,mirror extenders,centerstand. aftermarket:sw-motech: risers,trax 45L side cases 38L top case,pipe valve guard, kickstand foot enlarger. corbin/holshot heated seat ,MRA VarioTouringScreen,burkbusters storm,PC8, kaoko throttle lock, scorpion titanium slip-on, denali airbomb,scottoiler,denalli dx.pc5+autotune R&G:radiator guard, pipe slider K&N:air filter touratech:crashbars, ABS kill switch,dryspec tool tube,cyclops LED headlights,doubleback mirrors,helmet guardian,twowheels shorty levers,aftermarket off road rear brake lever,shorai lithium battery.
alon is offline
post #8 of 20 Old 05-23-2016, 04:07 PM Thread Starter
Zig-Zag's Avatar
Thanks Alon, I'll try that next time.
Zig-Zag is offline
post #9 of 20 Old 05-24-2016, 12:47 AM
Rolex's Avatar
As Alon said pull the 25a motor fuse and everything but the ABS will work as normal.
If you do decide to fit a switch you can turn the ABS off and on while moving, there is no need to turn the ignition off and on to reset the ABS.(I have not tried it at speeds above 60kph)
When I fitted my switch I only used a 15a fuse in the system just to see how much load the system was carrying and after 800ks the 15a fuse is still intact so the loads are not huge.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #10 of 20 Old 05-24-2016, 12:05 PM
You might want to test that with BOTH front and rear ABS activated, there may be separate pump circuits and you wont see the full amp draw until both are engaged. If you only tested with front or rear then may not be enough.
A signature
sdmdm8 is offline
