Using Seafoam additive - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 5Likes
post #1 of 21 Old 05-13-2016, 08:58 PM Thread Starter
pats's Avatar
I've heard that the old timer bikers always use this. Since we are using 93 octane fuel does it make any sense to use this additive. Unsure if it is a octane booster or cleaner.
pats is offline
post #2 of 21 Old 05-13-2016, 09:06 PM
ghm11's Avatar
I use it ,fuel system cleaner and crank case cleaner,I only use it in the fuel on the bike about every 6 months .put it in my car,truck crank case about 100 miles before i change the oil,have not done that on the bike.
Common Sense Isn't
Wee = The Swiss Army Knife of Motorcycles ,not great at anything ,but good at all.
The second time its not a mistake its a choice.
ghm11 is offline
post #3 of 21 Old 05-13-2016, 10:09 PM
Bugzy's Avatar
If your fuel pump gets noisy this might help, or if your bike sits a long time, maybe for bad gas.
It won't hurt anything as long as you don't use it every tank or something. I remember someone putting it on top of rubber washers and it caused them to expand, but it took a long time, and that was full strength, not mixed with gas.
Bugzy is offline
post #4 of 21 Old 05-13-2016, 11:38 PM
marcham's Avatar
I wouldn't use it every tank. It contains hydrocarbons and isopropanol which is a solvent but also absorbs moisture.
Sent from my SM-T700 using Tapatalk
2015 VSTROM 650 X ABS EXP
marcham is offline
post #5 of 21 Old 05-14-2016, 08:56 AM
Every tank is probably a waste of money. I've used it in some older cars/trucks in the crankcase for a short period to free up some sticking parts/clean up the top end. Makes a huge difference firing it through a vacuum line into the intake manifold though and it will smoke comically. Great stuff though, use it all the time in basically anything combustion.
ghm11 likes this.
MBZuki is offline
post #6 of 21 Old 05-14-2016, 09:18 AM
I would never put it in the oil. It will thin the oil and lower the lubrication properties. It might have some benefit in the fuel tank in cases of storage or bad fuel.
AlH likes this.
post #7 of 21 Old 05-14-2016, 09:36 AM
Lrobby99's Avatar
"Old timer bikers"?
I guess you meant that as a sign of respect.
My question is why are you burning premium fuel anyway?
Nothing wrong with Seafoam, but not on a regular basis unless you enjoy burning money too.
Lrobby99 is offline
post #8 of 21 Old 05-14-2016, 09:40 AM
Usefulness of Seafoam has no correlation to Octane rating.
post #9 of 21 Old 05-14-2016, 09:43 AM Thread Starter
pats's Avatar
OK how about sage ole riders!
Lrobby99 likes this.
pats is offline
post #10 of 21 Old 05-14-2016, 09:52 AM
You may have heard from old riders. How sage they are is debatable. Modern fuels, oils and engines are better. I wouldn't use Seafoam regularly any more than I would ever use STP in the oil.
