Rad guard installed - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
  • 2 Post By Bugzy
  • 1 Post By Bugzy
post #1 of 6 Old 05-12-2016, 06:33 PM Thread Starter
Bugzy's Avatar
Rad guard installed
I ordered a radiator guard from Yann at Enduro Guardian last week and it arrived two days later. ($70 USD)
I liked this one as it only requires the removal of one bolt at the bottom (easily accessed) and it looks functional with full coverage.
The install on a stock bike would be 5 minutes, but I have Givi crash bars and the mount bar that connects to the top radiator bolts gets in the way, so I had to trim the top corners of the guard a little for clearance. I started out with a hacksaw but that was a pain, then went to my bench grinder and had both sides adjusted in 5 minutes, very quick.
The unit looks great on the bike and will deflect rocks and sticks well, certainly a huge improvement over a stock radiator which is just hanging out there waiting for a big rock to punch a hole through it.
Solo Moto and IDRIDR like this.
Bugzy is offline
post #2 of 6 Old 05-12-2016, 08:20 PM
symbiotix's Avatar
I was looking at this guard and I too have the givi bars.... Any chance you could snap a pic of the modification needed?
symbiotix is offline
post #3 of 6 Old 05-12-2016, 08:25 PM
Solo Moto's Avatar
+1 for the Enduro Guardian radiator guard. One bolt simple install (w/ OEM Adventure crash bars), solid protection and just looks like it belongs there!
Current: '17 R1200GS Adventure, '16 DR650SE, '15 DR200S
Past: '14 DL1000A ADV, '07 DL1000, '01 K1200LTC, '89 ZX10, '81 KZ650, '75 DT400B
Solo Moto is offline
post #4 of 6 Old 05-13-2016, 01:11 AM Thread Starter
Bugzy's Avatar
The guard needs to hook over the top of the radiator, so it needs to be able to raise slightly higher, but the Givi bracket is very close to radiator on both sides, and won't allow it.
When you see it, you will see how it needs to be modified to work. It is very simple. Any kind of cutter or grinder will do for the modification, you might even get away with bending it.
symbiotix likes this.
Bugzy is offline
post #5 of 6 Old 05-13-2016, 12:36 PM
Any reviews yet with some miles? The air flow looks more restrictive than previous guards I have used...just wondering if increased operating temperatures have been noticed?
Sent from my XT1254 using Tapatalk
2015 DL1000 ADV
2thDr is offline
post #6 of 6 Old 05-13-2016, 01:24 PM
Solo Moto's Avatar
I just ride faster to increase airflow. Seriously, have noticed no issues after a couple thousand miles of use. We have previously discussed the Vee 2 temperature indicator stays constant at three bars no matter what level of hell you ride your bike into. No change with this rad guard. Go for it!
