oil leak - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 2 Old 05-09-2016, 03:27 PM Thread Starter
Gerardo Aguilar's Avatar
oil leak
hello, i am new in the site, i have a 2014 v strom 1000 . my trouble is a oil leak in the left side of the engine, somebody can tell me how to fix it.
thanks Gerardo Aguilar
Gerardo Aguilar is offline
post #2 of 2 Old 05-09-2016, 03:46 PM
It appears the wire bundle from the stator isn't properly sealed. Was that cover ever off? The best fix would be to remove that cover, clean all the oil away, and add silicone seal around the rubber block and to where the colored wires are exposed. The wire cover has been torn away from the block. You should not be able to see the wires. It's likely the cover will need a new gasket too. I've seen that on other models with aftermarket stators but I've never seen a report on a Vee2 stator problem that would have needed to happen if there was a stator replacement.
