Tire size. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 2 Post By randyo
post #1 of 9 Old 04-29-2016, 11:43 AM Thread Starter
Vdubfreak67's Avatar
Tire size.
Would it be bad juju to go up to a 160 70 on the rear?
Vdubfreak67 is offline
post #2 of 9 Old 04-29-2016, 05:28 PM
It would fit but might slow down the turnin when cornering due to the change in profile, it would also raise the back if going from as 150/70 to a 160
A signature
sdmdm8 is offline
post #3 of 9 Old 04-29-2016, 06:13 PM
randyo's Avatar
as a darkside experimenter I can absolutely say no problem, go for it, if ya don't like it, when the tire wears out, next time, go back to stock, any difference in handling you will get used to within the first 3 miles you ride, being a slightly larger tire, it may also have a better load rating
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #4 of 9 Old 04-29-2016, 06:18 PM Thread Starter
It's not for dark side.. But I may look into that. I want to run a Michelin commander 2 and they make the front in our size but the back is a 160 not a 150. If the wheel is the ride width it won't bubble in the middle.
post #5 of 9 Old 04-29-2016, 06:23 PM
randyo's Avatar
don't worry about the shape of the tire, I mentioned darkside only as an extreme example of changing tire size
RandyO
IBA# 9560
82 XV920R
www.gbhsurvey.com
randyo is offline
post #6 of 9 Old 04-29-2016, 06:32 PM Thread Starter
What I mean is that I put a 170 on a 160 wheel once and it destroyed the center patch in like 4500 miles. Because it arced the tire more in the center being on a smaller wheel width
post #7 of 9 Old 04-29-2016, 08:03 PM
randyo's Avatar
it wore in center note cause of arc but cause you didn't have enuf air and the rubber squirmed more and got hot
4500 miles on the rear of a 1000, while not great, is not bad either
other than darkside, best I have got with MC tire is 5000-7500 on rear of my Vee, don't expect the 10k+ that the 650 can get on a rear
RandyO
IBA# 9560
82 XV920R
www.gbhsurvey.com
randyo is offline
post #8 of 9 Old 04-29-2016, 08:07 PM Thread Starter
The 170 was a pr4gt on a st1100. It for sure had more arc in the middle of the tire.. At 42psi. Any extra weight even my wife would destroy it fast on the highway...
I do have a heavy throttl hand. I can get 18k out of a commander 2 cruiser tire on a heavy Harley... If I go 10mm wider I can run that. That's my plan right now because until I see a dark side v2 laying peg down.. I'm not down to try it yet
post #9 of 9 Old 04-29-2016, 08:10 PM
randyo's Avatar
I'm sure it had more arc, but that's not the cause of center wear on a motorcycle tire, get car tire mentality out of your mind, center wear comes from riding straight roads, accelerated wear is from inadequate pressure
tire temperature is derived from rubber squirm and is regulated by the pressure you run in your tires it 42psi isn't enuf, pump it up to 44 or 45
RandyO
IBA# 9560
82 XV920R
www.gbhsurvey.com
randyo is offline
