Master link - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
post #1 of 25 Old 04-26-2016, 09:08 AM Thread Starter
gman88's Avatar
Master link
So I'm almost due for a new chain . I stopped by the dealer and they are telling me that the swing arm needs to be removed because I don't have a Master link ... I looked at it and I believe they are incorrect so I'm going to attempt it my self any advice would greatly be appreciated .. Thanks
gman88 is offline
post #2 of 25 Old 04-26-2016, 09:16 AM
That's crazy. The chain can be cut or the pins on one link ground down to the side plates and pressed out with a chain tool. The new chain will have a master link. Go elsewhere.
Toto, Lrobby99, Larry33319 and 1 others like this.
post #3 of 25 Old 04-26-2016, 09:58 AM
Lrobby99's Avatar
Try a motorcycle dealership.
Lrobby99 is offline
post #4 of 25 Old 04-26-2016, 11:17 AM
Yeah if a shop tell you that back away and do not return. Every new chain comes with a master link be it clip or rivet.
If you do it yourself spend the money for the kit that has both the chain break and press tools included. Makes it a cake walk, just make sure to grind the head off the pin you pushing out when removing the chain otherwise you will have the chance of breaking your tool.
Here is an example of one such kit:
http://www.compacc.com/p/motion-pro-pbr-chain-tools
A signature
sdmdm8 is offline
post #5 of 25 Old 04-26-2016, 12:42 PM
Never ceases to amaze me, on how inept that too many dealers are.
post #6 of 25 Old 04-26-2016, 03:51 PM
ARATA's Avatar
I don't think they are being inept in this case, as much as dishonest.
2014 VS1K
2008 C14
2004 ZRX1200
1993 GSXR 1100
1990 V-Max (Gone to make room for the VS1K)
ARATA is offline
post #7 of 25 Old 04-26-2016, 03:56 PM
That too............
post #8 of 25 Old 04-26-2016, 04:06 PM
blaustrom's Avatar
You may want to study this thread. Has some useful info in it.
I am at a similar point and in the end it seems that the best price option is to get a DID 525 with the corresponding mater link and the DID chain riveting tool and you are all set. Next time it will cost you $100 to replace the chain.
If you use those links make sure you get the correct chain length for your bike!
blaustrom is offline
post #9 of 25 Old 04-27-2016, 12:07 AM
The factory chain is endless. No master link. It was installed before the swing arm shaft was put in. Cut it off with a chain cutter, or hack saw, or acetylene torch, or light saber. Or grind off a rivet head and push the pin out with the chain tool.
post #10 of 25 Old 04-27-2016, 01:11 AM
Sagebrush's Avatar
You just cut the OEM chain off, no need to remove the swing arm. Replacement chains use a master link. If you want to do your own chain replacement learn about master links. They make clip, rivet and screw types. EK has the screw type masters as an extra that require no chain tool or rivet work. 525 chains usually come with rivet masters. DID will come with a rivet or a clip type can be purchased etc.
Chains need to be the right length, usually you cut down a 120 link chain. So, you need to learn how to shorten chains. Google it. New chain means new sprockets, so you need the tools and know how for removal. Lots of threads around here if you want the how to guides.
Probably better off having a private motorcycle shop handle the work if your not handy with tools. I learned to do my own because I was tired of getting ripped off by motorcycle dealers and I had the tools already. Just don't let dealers over tighten the chain!
Sagebrush is offline
