FYI 1stGen VEE is bump startedable - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 2 Old 04-18-2016, 02:23 PM Thread Starter
snbdman's Avatar
Public service announcement.
If your battery is to week to turn the starter over but will prime the fuel pump the bike can still be bump started. Having a hill near by does help in the process.
snbdman is offline
post #2 of 2 Old 04-18-2016, 03:14 PM
Another FYI. The fuel pump sits in fuel. There is no way for it to go dry so priming is not what is happening when it makes noise. It has to get the fuel pressure up to 43psi. Then the pressure regulator valve opens to divert some fuel back into the tank so the pressure in the output pipe stays at 43psi. When that happens, the pump gets quieter.
As long as the pump has enough power to reach that 43psi, the engine can be bump started.
