Bike won't start, fuel pump not pumping - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
post #1 of 23 Old 04-09-2016, 12:44 PM Thread Starter
Got my bike back from the dealership for the recent recalls. Was riding it the other day and it shut off going down the road and wouldn't start again. Says "chec" on the display, and I noticed the fuel pump isn't making any noise when I turn on the switch. Any ideas? I just checked the connector to the fuel pump and changed out the fuse, no luck there. 2014 DL 1000A.
jacej86 is offline
post #2 of 23 Old 04-09-2016, 12:46 PM
Vdubfreak67's Avatar
What recall? If they pulled the tank off you very well could have a loose wire. Happened to me.
Vdubfreak67 is offline
post #3 of 23 Old 04-09-2016, 12:49 PM Thread Starter
I don't remember exactly, I know it was three separate recalls, and at least one of them required the tank to be removed.
jacej86 is offline
post #4 of 23 Old 04-09-2016, 12:56 PM
V-Tom's Avatar
Check the dumb things first... is the kill switch on? Was the side-stand up in gear?
..Tom
SMIDSY detailed report.
V-Tom is offline
post #5 of 23 Old 04-09-2016, 12:59 PM Thread Starter
Bike in neutral, tried both kick stand up and down. No dice.
Vdub, what connector was loose in your case?
jacej86 is offline
post #6 of 23 Old 04-09-2016, 01:06 PM
VSrider's Avatar
A blown main fuse will cause a "chec" also.
VSrider is offline
post #7 of 23 Old 04-09-2016, 01:21 PM Thread Starter
I just tried to main 30A fuse idea, checked it, look fine, then replaced it with the spare for good measure. Still says "chec" and won't start.
jacej86 is offline
post #8 of 23 Old 04-09-2016, 01:26 PM
Not the main fuse but the ignition fuse may be blown. That and the kill switch, side stand switch and the wiring for them are the usual suspects. They will cause a CHEC and prevent the fuel pump from running.
post #9 of 23 Old 04-09-2016, 05:59 PM Thread Starter
Checked and changed all the fuses, no luck there. I guess it's time to break out the multimeter...
jacej86 is offline
post #10 of 23 Old 04-09-2016, 07:47 PM
York's Avatar
"FI"
Jacej86, I get the CHECK in the display when the kill switch is off. At the same time the gear indicator will only show "-".
However - the red FI indicator (11) will stay on when turning the ignition on until the odometer/trip (20) comes up. After that the FI indicator will TURN OFF.
What is your display doing?
Check the NOTICE and NOTE on page 2-13 of the manual
jacej86 likes this.
Ride - Life Is Too Short!
York
York is offline
Tags
2014 dl1000 adv , fuel pump , issue , recall , won't start
