New PC-8 harness available for DL1000A 2014+ - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
  • 1 Post By 2thDr
  • 1 Post By 2thDr
  • 1 Post By 2thDr
post #1 of 7 Old 03-31-2016, 12:12 AM Thread Starter
Now Eastern Beaver has a PC-8 harness that is designed for the new V2. I believe he used info from Tipsy's custom installation. I have a link to a photo of mine below and will post up how the install goes. Just laying it out on the bike looks like it is done well, allowing one to run it down the left subframe tube like Tipsy's install.
https://goo.gl/photos/yqbZhYHHre2TgqcY7
Sent from my Nexus 7 using Tapatalk
Solo Moto likes this.
2015 DL1000 ADV
2thDr is offline
post #2 of 7 Old 04-01-2016, 10:00 PM Thread Starter
OK already ran into a problem. Correct me if I am wrong, but it looks like the harness has a two prong connector and the brake/tail light harness has 4 prong connectors. Am I looking at the wrong bike harness connector?
Linky to photos:
2015 DL1000 ADV
2thDr is offline
post #3 of 7 Old 04-02-2016, 12:29 AM
stu53's Avatar
You need to use the connection from the foot brake switch. It's located above the foot brake. Easy to find with the seat off.
stu53 is offline
post #4 of 7 Old 04-02-2016, 11:42 AM Thread Starter
Thanks, I got a reply from Eastern Beaver last night. The connector in question is located amid bike, under the forward part of the seat, forward of the battery and aft of the coolant overflow reservoir, just about on top of the ABS control unit. If anyone wants a photo, let me know today...LOL
stu53 likes this.
2015 DL1000 ADV
2thDr is offline
post #5 of 7 Old 04-04-2016, 12:58 AM Thread Starter
Finally got everything wired up...PC-8, GPS powered rugged mount, TAPP USB power port, Oxford heated grips, Gerbings heated gear connections. My wiring jobs never look pretty...
kustard likes this.
2015 DL1000 ADV
2thDr is offline
post #6 of 7 Old 04-04-2016, 05:40 AM
The inline fuse holders (red arrows) are redundant.
Why bother with an auxiliary fuse block if your going to connect virtually everything you're running directly to the battery? It looks like you've got no fewer than four ring terminals connected to the battery - three accessories plus the PC-8 connections.
Tipsy
Givi Trekker Outback Luggage, Givi Crash Bars, Givi Hugger, Givi Kick-Stand Foot, Happy Trails Skid Plate, Suzuki Center Stand, Barkbusters, Barkbuster LED DRL's, Dynamic Motorrad LED Turn Signal Bulbs, Skene P3's w/ Stock Tail/Brake Light on IQ-160 Controller, Cree Spot/DRL's on Denali Bar w/Skene IQ-275 Controller, Kaoko Throttle Lock, In-Dash USB Power Port, EB PC-8 Aux Fuse Box, Garage Door Remote, Garmin Zumo 660LM on AdventureTech Windscreen Mount, Aprilia Tuono Mirrors, SAE Battery Tender Dongle, Bags Connection Evo-Engage Tank Bag
TipsyMcStagger is offline
post #7 of 7 Old 04-04-2016, 08:12 AM
NyMeTsFaN912's Avatar
Can you list the part number for the V2 please? Also, how many amp relay and how many inches? Electronics is the one class that I skipped.
-John
NyMeTsFaN912 is offline
